blower motor not turning on
Old Oct 21, 2003 | 02:40 PM
riceboyEFsi's Avatar
Default blower motor not turning on
my blower motor will only turn on w/ direct 12 volts and direct ground . Any ideas and yes the resistor is new
Old Oct 21, 2003 | 02:42 PM
USDM 4G VTEC's Avatar
Default Re: blower motor not turning on (riceboyEFsi)
maybe somethings wrong behind the actual dash console..... check the actual switch that moves around.....
Old Jan 25, 2004 | 10:08 AM
blower motor fan will still not turn on unless given direct power and ground from the battery . I installed new switch, new resister checked my fuses , double checked my fuses and still nothing . Cmon guys its mad cold out
Old Jan 25, 2004 | 10:44 AM
hondatim's Avatar
have you checked for power at blower motor connector? Also, have you checked continuity to ground on groud side of circuit?
Try this before replacing anything else and let us know...
Old Jan 25, 2004 | 12:07 PM
Default Re: blower motor not turning on (hondatim)
no i havent this will be the next step thanx 4 your response . Any other suggestions?
Old Jan 25, 2004 | 01:16 PM
deftones0817's Avatar
I have the exact same problem...i just got the car the heat worked one day and then the blower wouldnt come on. I have been driving all week with no heat. I finally got the trunk to latch and lock today so the car is a little warmer...but I have tried everything you have i had the whole thing apart today. Could the climate control make the blower not turn on...because my climate control looks like some kid kicked it into the dash and the tabs are broken off so i cant make it stay in one spot.
DEF
ps sorry to hijack your thread
Old Jan 25, 2004 | 03:09 PM
tilt's Avatar
http://www.binghamtonlife.com/...r.htm
Old Jan 25, 2004 | 03:20 PM
IwantaGlock18's Avatar
Default Re: blower motor not turning on (tilt)
Mine does this too. I thought it was because my climate control was broken in half. So I just wired it straight to the battery, put a fuse and switch inline and you got yourself a getto heater, but it is still a heater.
JeanGeslin
Jan 15, 2019 03:13 PM
pityocamptes
Aug 9, 2014 09:03 PM
xkellyxveitx
Nov 14, 2010 09:05 PM
bodiez
May 13, 2008 07:27 PM
bretx0r
Aug 12, 2005 03:21 PM
