Wastegate gasses are killing me !!!
Old Oct 20, 2003 | 10:58 AM
brkrnu's Avatar
Default Wastegate gasses are killing me !!!
I have a dumptube but the fumes and exhaust smoke are killing me. It is coming through a hole in my firewall too.
Are others having the same problem ??
How far down does the tube need to go before it gets sucked out under the car ?
Old Oct 20, 2003 | 11:03 AM
R6Elmo's Avatar
Default Re: Wastegate gasses are killing me !!! (brkrnu)
i have mine pointing to the ground...basically where the frame ends. Thats enough for it to just go under the car. I say fix that hole in your firewall.
Danny
Old Oct 20, 2003 | 11:04 AM
brkrnu's Avatar
Default Re: Wastegate gasses are killing me !!! (R6Elmo)
I'm going to but I haven't had time since I fished my wideband wires and boost gauge hoses thru that grommet behind my battery.
Old Oct 20, 2003 | 11:36 AM
KC GSR's Avatar
go to autozone and buy one of those flex hose exhaust repair kits, or whatever they are. I bought a 2" one and attached it to the end of the dumptube, and it runs even further down and dumps out sideways by the oil pan
Old Oct 20, 2003 | 11:40 AM
quikB18B's Avatar
Default Re: Wastegate gasses are killing me !!! (KC GSR)
Guess college is paying off for KC Gsr
Nice budget idea for a quick fix
Old Oct 20, 2003 | 01:48 PM
aznxphreak's Avatar
Default Re: Wastegate gasses are killing me !!! (quikB18B)
You sure it isn't coming from your breather? I don't smell anything from my wastegate, just fumes from the breather hole.
Old Oct 21, 2003 | 05:11 AM
brkrnu's Avatar
Default Re: Wastegate gasses are killing me !!! (aznxphreak)
I checked my wastegate last night and I figured out that I forgot to put on the gasket between the manifold and the wastegate.
Doh !!
I also duct taped the grommet in my firewall which is right behind the battery and that should eliminate the gas fumes.
Old Oct 21, 2003 | 05:16 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brkrnu &raquo;</TD></TR><TR><TD CLASS="quote">
I also duct taped the grommet in my firewall which is right behind the battery and that should eliminate the gas fumes.</TD></TR></TABLE>
thats my quick solution too ALthough, Im not taking that route on my next project w/the gas tank up front, I want as much firewall there just incase something goes wrong.
thegatekeeper14
Aug 17, 2009 12:39 PM
keving85
Mar 5, 2009 12:12 PM
T--Rex
May 20, 2005 03:29 PM
crazyimport
Jul 14, 2004 06:08 PM
Built B16A
Feb 18, 2004 12:02 PM
