gsr obd1 jumper question
Old Oct 15, 2003 | 06:31 PM
lrgsrhb's Avatar
Default gsr obd1 jumper question
i've been running my 98 gsr swao with a 99 si ecu...installed the jumper and a obd1 gsr ecu today and fixed the issues that i had, but things sound different.....i was used to v-tec engaging realy loudly @ around 5400, but now it sounds like 4900 and the power doesn't feel as jolting as before...haven't dyno'd yet though...
anyway can someone help shed some light on what i might be hearing or not hearing (feeling or not feeling)
thanks in advance tech guys for the help
Old Oct 15, 2003 | 09:11 PM
lrgsrhb's Avatar
Default Re: gsr obd1 jumper question (lrgsrhb)
bump
Old Oct 15, 2003 | 10:38 PM
mmuller's Avatar
Mad Scientist
because the p72 engages vtec at 4400
Old Oct 15, 2003 | 11:16 PM
PHiZ's Avatar
Default Re: gsr obd1 jumper question (mmuller)
Your secondaries (IAB) are probably wired wrong.
Although the tone on the B16 and B18c1 are different...
-PHiZ
Old Oct 16, 2003 | 08:23 PM
lrgsrhb's Avatar
Default Re: gsr obd1 jumper question (PHiZ)
ahhh, 4400... now that i had a day to drive i figured out that it was ingaging a lot lower...can someone tell me why??????....is that better???
and the 2nd's are wired open....the car has a si harness, so does that butterfly being open all the time take away from performance??????....what would you guys do...????
p.s. 99 civic hatch w/ 98 gsr/ spec stage three, pully's, intake,2.5 exhaust, and kumho V700's....
Old Oct 16, 2003 | 08:25 PM
lrgsrhb's Avatar
by the way PHiz i have a bumper...holla
Old Oct 16, 2003 | 09:49 PM
mmuller's Avatar
Mad Scientist
on the b18c1 vtec is able to ungage at 4400 because of the secondaries.yes you are loosing a lot of midrange with sec. open. i would wire it
Old Oct 16, 2003 | 11:32 PM
PHiZ's Avatar
The secondaries are there to provide a narrow path for the air, incresaing velocity, and giving low-end torque. At high-rpms they open up to get less velocity, but more volume.
-PHiZ
Old Oct 17, 2003 | 02:55 AM
racerboyb18c1's Avatar
its ok with them open all the time for racing u loose like 10 ft lbs of torque , ive seen this on the dyno with em open all the time, also i ran a skunk 2 obd1 p61 in my eg with a stock gsr motor and had vtec at 5500 , i dont know bout u guys but i like it later pulled harder before vtec and when it cam on it was way harder and sounded like a b series should, but im sure it lost some down low , but who races at a idle?
Old Oct 17, 2003 | 06:14 AM
lrgsrhb's Avatar
Default Re: gsr obd1 jumper question (racerboyb18c1)
thanks guys......ttt......
hcope316
Mar 9, 2009 08:54 AM
CA6VTEC
Oct 3, 2006 02:32 PM
Novtecdohc
Mar 4, 2006 10:07 PM
NA JDM GSR
Jul 7, 2005 08:01 AM
matttegra
Sep 24, 2003 04:16 PM
