Spark Plug/heat range Q's (help)
Old Oct 15, 2003 | 02:52 PM
Shft@9GSR's Avatar
Default Spark Plug/heat range Q's (help)
My questions are... can running too hot of plug contribute/cause detonation?
With that in mind... will too hot of plug increase Exhaust Gas Temps?
Also... when reading a plug number... for a GSR... PFR6G-13... Can you break that down to english for me?
Is the 13 the heat range? Would a cooler plug be PFR6G-11 like for the ITR?
Any information would be greatly appreciated. Thanks in advance.
Old Oct 15, 2003 | 07:07 PM
Rtype16's Avatar
Default Re: Spark Plug/heat range Q's (Shft@9GSR)
Yes running to hot of a plug can create detonation in the cylinder. The letters on the spark plug mean different things by different manufacturers. The PFR stands for the reach and thread usually and the -13 is the type of tip usually on the spark plug the 6 is the actual heat range. Changing to the other plug won't do much. If you are looking for a colder plug just pick up some BCRP7ES or higher cheap NGK plugs, but work great.
Old Oct 15, 2003 | 11:54 PM
globlctzn's Avatar
Default Re: Spark Plug/heat range Q's (Rtype16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Yes running to hot of a plug can create detonation in the cylinder. The letters on the spark plug mean different things by different manufacturers. The PFR stands for the reach and thread usually and the -13 is the type of tip usually on the spark plug the 6 is the actual heat range. Changing to the other plug won't do much. If you are looking for a colder plug just pick up some BCRP7ES or higher cheap NGK plugs, but work great.</TD></TR></TABLE>
Like he said except the -11 -13 whatnots are what the plug is pre gapped at. -11 is pre gapped at 1.1mm -13 at 1.3. If there is no -# after a NGK plug it isnt pre gapped.
Old Oct 16, 2003 | 04:38 AM
JimBlake's Avatar
Default Re: Spark Plug/heat range Q's (globlctzn)
From something I found once on NGK's website, but I can't find it there anymore...
PFR6G-13 GS-R
PFR6H-10 Saab
P = platinum
F = metal shell size
(14mm dia, 19mm reach, 16mm hex)
R = resistor
6 = heat range
(2=hot, 11=cold)
G,H = firing end construction
(my list doesn't define them but my Saab takes 'H' & I got confused...)
-13 = pre-gapped to 1.3mm
Modified by JimBlake at 5:36 PM 10/16/2003
Old Oct 16, 2003 | 11:04 AM
Shft@9GSR's Avatar
Default Re: Spark Plug/heat range Q's (JimBlake)
Thanks to all that replied. That was all very useful information. At least now I know what my probem is.
Old Oct 16, 2003 | 11:12 AM
wickedEFguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">From something I found once on NGK's website, but I can't find it there anymore...
PFR6G-11
P = platinum
R = resistor
6 = heat range
(2=hot, 11=cold)
ok so what does the G stand for then before the 11?
Old Oct 16, 2003 | 12:04 PM
Rtype16's Avatar
Default Re: Spark Plug/heat range Q's (Ninja_Jc7)
Sorry I was at home when I made that post so I was just going off the top of my head. So lets go back again and explain all the symbols of this spark plug just to recap.
PFR6G-11
P = Plug Type = Premium Platinum
F = Metal Shell Size = Diameter 14mm, 19mm Reach, 16mm Hex
R = Construction = Resistor
6 = Heat Rating Numbers (2 = Hot, 11 = Cold) = 6
G = Firing End Construction = Nickel Alloy Center Electrode
11 = Wide Gap = 1.1mm
ravinaziankid
Aug 14, 2012 05:25 PM
irdprelude
Feb 23, 2005 07:29 PM
princeallure
Jul 12, 2004 07:33 PM
Mefain
Jun 3, 2003 10:15 AM
