help with d16z6 ecu swap
Iam doing the same thing right now. What i know is you need the p28 ecu the newer distributor and a four wire o2 sensor. You also need a wire harness jumper that connects the old wire harness to the new ecu. Check out http://www.hasport.com for more info on the wire harness.
ProjectOneTexas
Sep 15, 2014 06:12 AM
DiPPeD iN miLk Ej CoUpE
Mar 10, 2003 03:26 PM
