Valve Spring Nut missing...is this bad?
Old Oct 15, 2003 | 10:22 AM
incognitoracerr's Avatar
Default Valve Spring Nut missing...is this bad?
when I went to adjust my valves earlier this morning I notice I had two nuts of the intake screws missing on Cyl. #1. I found one near the spring of the valve on Cly. #1 but the other nut I could not find. I looked all over the head and nothing...I even used an extension magnet and did not get anything...I also stuck the magnet down the oil holes and nothing...i also remove the spark plugs and stuck the magnet to each piston and nothing...do you think somehow it may have gone down to the oil pan?...I check my cam lobes and they are fine...no signs of wearness or damage...is this something I have to worry a lot about...I replaced the nut I could not find with one from another head
Old Oct 15, 2003 | 10:41 AM
rsbad454's Avatar
Default Re: Valve Spring Nut missing...is this bad? (incognitoracerr)
drop the oil pan...................could be in pan or on top of windage tray......
Old Oct 15, 2003 | 11:57 AM
CaptainDoogles's Avatar
Default Re: Valve Spring Nut missing...is this bad? (rsbad454)
i had the same issue with my 92 but a buddie of mine didn't tighten the nut all the way. its probly in the pan. <U></U> MAKE SURE IT DIDN'T GO UNDER THE CAM. <U></U> use like a coat hanger point to find it under the cam give it a crank or two so u get up the cam good if not its probley at the bottom of the pan. u will have to drop the exust and pan. get a new gasket regardless of what anyone says. its like $20 and u dont want to do this again.
P.S. THE NUT IS ALUMINUM SO U WILL NOT FIND IT WITH A MAGNET.
Old Oct 15, 2003 | 12:02 PM
spaceman's Avatar
if you know that nut is in there somewhere..you better find it
Old Oct 15, 2003 | 12:23 PM
Default Re: Valve Spring Nut missing...is this bad? (spaceman)
The screw does get on the magnet because that how I took the other one out...but its not underneath the cam because i looked...maybe its in the pan like you said....
Old Oct 15, 2003 | 12:41 PM
what yr and make is ur car i had a 92 civic dx 1.5 the nuts were aluminum on mine. if its like my engine u don't have to worry about the pump pumping it up but in really clean and don't like things in place . i worry so i did the work again. (i already had the engine out the first time.lol)
Old Oct 15, 2003 | 12:45 PM
Default Re: Valve Spring Nut missing...is this bad? (CaptainDoogles)
my engine is a B16a1 sir2
Old Oct 15, 2003 | 01:01 PM
i dont know honda told me the valve nuts were locking aluminum. and the other engines had aluminum nuts to. i was trying to find that engine to put in my candy paint blue civic. http://www.mcmullenargus.com/g...ub=41
Old Renegade
19
Dec 11, 2007 04:12 AM
zman
Nov 30, 2004 03:52 PM
Flux
May 15, 2004 07:58 PM
incognitoracerr
Oct 15, 2003 11:24 AM
Ash J. Williams
Jan 23, 2003 04:55 PM
