Ignition Problem
Old Oct 14, 2003 | 04:25 PM
Tru_Hybrid's Avatar
Default Ignition Problem
Okay, my car will not start. First the car will turn over, but it will not create any spark to start the engine. My ignition system consist of a msd ignition control and msd coil blaster, and it is on a ls distributor. I have magnacore 10mm wires with NGK r stock plugs.
I got the car to start, and when I went to test out the car; I revved the engine to about 7000 rpm and the car sputtered and died. So I'm not sure what the problem is. Some people said it might be my msd, or bad coils. Please tell me how I can fix this problem if anyone can understand what I am trying to say. The distributor is not making any spark, and I would appreciate any help available. Thanks in advance.
Old Oct 14, 2003 | 07:04 PM
solo2slocivic's Avatar
test the ignitor (icm).. quick test disconnect the msd input wires from the dizzy & put test lite between them and have someone turn over the car if the lite flashes the ignitor is ok... and you problem is something else... either the msd or other.. to test the msd box hook the wires back up between the dizzy and msd box and remove the coil - and + and perform the same test.....
Mooch
10
Jul 20, 2009 03:29 PM
chahsiubow
Jul 12, 2005 05:38 PM
K-Spec
Jan 8, 2005 03:48 PM
toooslow
Aug 20, 2003 09:12 PM
