chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
Old Oct 14, 2003 | 02:47 PM
baphomet's Avatar
Default chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
Old Oct 14, 2003 | 02:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu? (
swaping out an ecu should kill the memory, but if not just undo the battery.
Old Oct 14, 2003 | 03:03 PM
omahaturbocivic's Avatar
Unplugging the ecu is all that needs to be done to clear it. I have changed chips at the track with only shutting the car off and the launch rpm would change but I believe blake had observed that the fuel may not instantly be changed even in open loop unless the ecu is cleared.
Old Oct 14, 2003 | 04:24 PM
baphomet's Avatar
I was concerned about maybe blowing a fuse or something if thebatery was connected.
Old Oct 14, 2003 | 05:42 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Naw i never had a problem
Old Oct 14, 2003 | 06:27 PM
Mr. Softee's Avatar
no, thank god.
jamclaur
Jul 21, 2005 09:04 AM
T--Rex
Jul 27, 2004 10:53 PM
bigslimdog
Mar 30, 2004 03:07 PM
dvcart106
Aug 9, 2003 12:42 PM
rock2447
Jan 15, 2003 02:42 PM
