Change stock oil cooler on a B18C5 when rebuilding after spinning a rod bearing?
Old Oct 14, 2003 | 09:32 AM
canuck-mx6's Avatar
Default Change stock oil cooler on a B18C5 when rebuilding after spinning a rod bearing?
Do you have to change the oil cooler? The machine shop is saying that the cooler could contain metal shavings and should be changed. Is this absolutely necessary?
Old Oct 14, 2003 | 12:52 PM
canuck-mx6's Avatar
Default Re: Change stock oil cooler on a B18C5 when rebuilding after spinning a rod bearing? (canuck-mx6)
bump, someone has to know the answer to this
Old Oct 14, 2003 | 01:14 PM
SimbaDogg's Avatar
i wouldn't do it...lots of shops like that will bullshiet you into getting more work done from them. if anything, get a front mount oil cooler, that'll give you way more cooling that the stock unit
LS97Civic
Apr 24, 2012 07:48 AM
b18cvtec
Feb 11, 2005 10:07 AM
Rain_man
Jun 20, 2002 03:42 PM
