B20a/b or b20z swap question?
Old Oct 13, 2003 | 01:04 PM
sleepyhamsterlx's Avatar
Default B20a/b or b20z swap question?
Ok, this is going into a EK, is there any different way to install one from the other in terms of wiring, etc. And putting a VTEC head will it make a difference which block i have
Old Oct 13, 2003 | 01:17 PM
Default Re: B20a/b or b20z swap question? (Mgnlxsd)
basically is the block different or just the internals
Old Oct 13, 2003 | 01:50 PM
BLK JDM's Avatar
NEVER use the B20A motor. That is from the old school prelude and is no where close to being the same as the B20B/Z. The B20Z has higher compression and has VTEC type oil pump. To get the B20 into a civic you need to get all B-series parts. You need a B-series tranny, mounts, axles, shift linkage, and A/C parts if you want A/C.
Old Oct 13, 2003 | 06:37 PM
Default Re: B20a/b or b20z swap question? (jigga008_99)
What? never heard the B20z's comes w/vtec Type oil pump, so if i was going to put a b20z then there wouldn't be any difference in swaping a b20b or b20z external wise
Old Oct 13, 2003 | 06:51 PM
well can't find a good site for a Ek b20z swap, w/or w/o vtec, anything to put a b20 into a EK
Old Oct 13, 2003 | 06:54 PM
JDM-97CX's Avatar
go to jdmhondaparts.com they have b20 longblocks for sale
Old Oct 13, 2003 | 07:45 PM
13BT's Avatar
hrm...anyone know anybody who sells the b20 complete swaps?
Old Oct 13, 2003 | 07:50 PM
DenMatic's Avatar
all b-series engines 1997(98?)-up come with the "vtec" oil pump according to your local honda dealership
just check it against the part numbers when you go to parts.
Old Oct 13, 2003 | 08:14 PM
BLK JDM's Avatar
Default Re: B20a/b or b20z swap question? (DenMatic)
I know my 98 stamped USDM B20B4 did not come with a VTEC type oil pump.
czirr321
11
Mar 31, 2012 06:56 PM
jeanhernandez
Dec 4, 2010 10:24 AM
Dnug
Oct 12, 2010 03:40 PM
raidacaipo
24
Jan 29, 2009 09:06 PM
H23vtecEG
Feb 11, 2003 07:19 PM
