help me!
Old Oct 13, 2003 | 11:12 AM
hondapro_2005's Avatar
Default help me!
I have a gsr block with stripped threads for the head bolts.
I wanted to know if there is a helicoil kit that can be used, one w/enough threads.
Or if a machine shop can fix this??? Threaded inserts???
thanks for the help
Old Oct 13, 2003 | 11:32 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: help me! (b20eg)
yeah there is but always take it to a machine shop when **** like that happens
Old Oct 13, 2003 | 08:19 PM
i am thinking of trying a helicoil??
should i try it??
any input is appreciated.
thanks
Old Oct 13, 2003 | 08:25 PM
rsmotors's Avatar
I've done alot of helicoil. If you are confident and really careful
you can do it. I buy my set at Napa. It is also useful to have the tap to try out intead of the bolt. Same size tap as the original bolt. Then you have to buy a drill bit for the helicoil. It normally says it on the helicoil tap what size drill bit you need
jinxd12
17
Feb 23, 2011 02:59 PM
ppfalcon
Oct 14, 2005 10:19 PM
toooslow
Jun 18, 2003 10:01 AM
SjCiViCHB
Jan 18, 2003 01:47 PM
nugget8000
Aug 26, 2001 12:13 AM
