stripped threads on block
Old Jun 15, 2003 | 02:24 AM
toooslow's Avatar
Default stripped threads on block
The idiot that had my car before put in wrong tranny bolts or something because the threads on block are stripped and the bolts wont tighten. Where can i take this to have it fixed? can i go to a transmission shop or do i have to take it to a machine shop?
Old Jun 15, 2003 | 05:33 AM
3gdude's Avatar
Default Re: stripped threads on block (whiteinteg95)
Buy a Heli-Coil Kit and fix it yourself, cost about 30$.....3gdude
Old Jun 15, 2003 | 07:58 AM
toooslow's Avatar
what is it, and where can i buy?
Old Jun 15, 2003 | 08:12 AM
3gdude's Avatar
Default Re: (whiteinteg95)
You can get them at any good auto parts store. You need to know your thread size though, so take one of the good bolts with you to match up. Its basically a steel coil that you thread into the aluminum, that allows you to restore threads back to original size. It will be stronger than before. Read directions on package...3gdude
Old Jun 15, 2003 | 12:37 PM
toooslow's Avatar
so when it rethreads, it doesnt make the bolt size larger, it sorta just fixes the original sized threads?
Old Jun 15, 2003 | 12:40 PM
koco's Avatar
I used a Helicoil to fix a stripped exhaust manifold bolt. 2 of them actually. It worked rather well. I'd say it's your best bet. Napa can match one up for you. You'll need the right sized drill bit to drill out the hole, the drill size needed is on the helicoil package.
Old Jun 15, 2003 | 01:00 PM
toooslow's Avatar
koco - how much was the helicoil you bought
Old Jun 15, 2003 | 01:26 PM
Supernatural's Avatar
helicoil....but you have to make some kind of super long extension for the thread bit to reach into the block...weve had to do it once in a while
Old Jun 15, 2003 | 03:28 PM
toooslow's Avatar
i went to pepboys and kragen and they said they didnt have bit that was big enough. What is the size of the tranny bolt threads, i think its m12 or something.
Old Jun 16, 2003 | 08:52 PM
88LXi68's Avatar
I have the same problem as well
Old Jun 17, 2003 | 09:09 AM
PSU-TEG's Avatar
Well, I'm not sure what to tell you about needing the long extention reach the hole.
But I would suggest using "Time-Serts". They are a little more expensive than helicoils. But they are much easier for amaturs to work with.
http://www.timesert.com
I used them to repair all three of my Drive-side Engine mount holes in my block. It was really easy (just take your time and be patient). That was about a month and a half ago... no problems so far.
Old Jun 18, 2003 | 10:01 AM
koco's Avatar
The whole deal cost me about $45. I bought the drill bit too.
Htounndea
Apr 16, 2012 10:08 AM
boostedefhatch
May 9, 2010 09:06 PM
webbs2jzgte
Jan 24, 2009 08:38 AM
slowassciv33
Apr 19, 2006 12:51 PM
crex23
Mar 14, 2006 11:12 AM
