spark plug help!
Old Oct 13, 2003 | 10:28 AM
Scharged2000GsR's Avatar
Default spark plug help!
I bought new spark plugs for my teg. they came stock at 45. i need them to be 30-35. could i just hit it with some wood and a hammer. or would that fu*k the spark plug up.
Old Oct 13, 2003 | 10:35 AM
Tweakmeister's Avatar
Default Re: spark plug help! (Scharged2000GsR)
the gapping?
if you have a gapping tool then just press the plug against a piece of wood.
Old Oct 13, 2003 | 10:50 AM
Default Re: spark plug help! (Tweakmeister)
yes the gapping but that wont do anything to the skark plug, it'll be fine?
Old Oct 13, 2003 | 11:53 AM
FastNFurious
Guest
Posts: n/a
dude, just push the end piece down with something metal. You don't need to ****** pound the thing.
Old Oct 13, 2003 | 12:00 PM
EL Vap133's Avatar
It will bend easily, you just got to slightly tap on it.
Old Oct 13, 2003 | 12:32 PM
wcsinx's Avatar
Do none of you own a proper gapping tool? Don't whack on the electrode. That's just stupid. You see that t-shaped claw thingy on the end of an actual spark plug gapper? Grab the base of the electrode with it, and gently pry in or out to get the proper gap.
Old Oct 13, 2003 | 12:43 PM
Default Re: spark plug help! (wcsinx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wcsinx &raquo;</TD></TR><TR><TD CLASS="quote">Do none of you own a proper gapping tool? Don't whack on the electrode. That's just stupid. You see that t-shaped claw thingy on the end of an actual spark plug gapper? Grab the base of the electrode with it, and gently pry in or out to get the proper gap.</TD></TR></TABLE>
I have a Snap-On tool for opening, but to close it you just press it down with whatever.
Said pressing tool sounds....nice.
Old Oct 13, 2003 | 01:02 PM
tb_pimpjuice's Avatar
lol hammer it down...just don't hit your thumb!
Old Oct 13, 2003 | 01:07 PM
yes i have a spacing tool thats how i found out what the spacing was. all i need to know was how to make it smaller without ******* it up. dick!
Old Oct 13, 2003 | 04:25 PM
garados's Avatar
i just gently tap it against the ground
Old Oct 14, 2003 | 01:42 PM
Mns's Avatar
Mns
Don't gap your plug!
Try this: http://plugs.janmax.com/
Modified by Mns at 6:14 PM 10/14/2003
Old Oct 14, 2003 | 03:28 PM
beaterman's Avatar
Default Re: spark plug help! (Mns)
so when i put some new ngk plugs into my car i needed to gap them. what is the stock gap for a 99 ls. also what is the stock gap of ngk v-power plug.
Old Oct 14, 2003 | 04:23 PM
lke2drvgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mns &raquo;</TD></TR><TR><TD CLASS="quote">Don't gap your plug!
Modified by Mns at 6:14 PM 10/14/2003</TD></TR></TABLE>
ngk's came in the box gapped 1.1, my gsr requires 1.3 gap.. gapping tool is 3 bucks at any local auto shop, takes 15 seconds to gap them. gsr and type r DO NEED gapping. check the manual.
Old Oct 14, 2003 | 04:38 PM
beaterman's Avatar
Default Re: spark plug help! (lke2drvgsr)
so what is the stock gapping for a 99 ls integra. could not gapping the plugs properly lead to poor gas mileage and bad 1/4 mile times?
Old Oct 14, 2003 | 04:49 PM
Mns's Avatar
Mns
Default Re: spark plug help! (beaterman)
Make: ACURA
Model: INTEGRA - LS
Year: 1999
Engine: L4 - 1.8 - B18B1
Stock gap 0.044
Suggested NGK: ZFR5FIX-11 http://ngk.com/results_cross.asp?pid=PZFR5F-11
Suggested BRISK: DOR17LGS http://plugs.janmax.com/msearch.aspx
Old Oct 14, 2003 | 05:05 PM
beaterman's Avatar
that helped zero amount. and the plugs i bought were the exact same as the stock ones.
ravinaziankid
Aug 14, 2012 05:25 PM
integra93
Dec 30, 2003 04:17 PM
Mefain
Jun 3, 2003 10:15 AM
