Brake Bleeder Screw HELP...need size..
Old Oct 13, 2003 | 10:12 AM
SloCivicHMM's Avatar
Default Brake Bleeder Screw HELP...need size..
Does anyone know the bleeder screw THREAD size? the lil nipple thing on the actual caliper......
I have vx brakes up front and teg discs in the back....thanks...I can't find ****...lolz
Modified by SlowCivicHmm at 11:20 PM 10/13/2003
Old Oct 13, 2003 | 11:05 AM
legrac95's Avatar
Default Re: Brake Bleeder Screw HELP...need size.. (SlowCivicHmm)
10mm
Old Oct 13, 2003 | 11:35 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Brake Bleeder Screw HELP...need size.. (legrac95)
its 10 mm on every honda as far as i know but if u are going to use a wrench then use the closed in or a brake bleeding tool because open ended wrenches can strip the bleeder valve
Old Oct 13, 2003 | 11:59 AM
Default Re: Brake Bleeder Screw HELP...need size.. (streetdreams02)
I meant the thread size.....
BTW: teg rear disc are 8mm and civic front are 10mm
But I need the t hread size due to the fact I'll be getting SPEED BLEEDERS
Old Oct 13, 2003 | 02:20 PM
TTT
Old Oct 13, 2003 | 02:25 PM
sleepyEK's Avatar
i think they are 8mm threads.
Old Oct 13, 2003 | 07:41 PM
AngryTroll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">I meant the thread size.....
But I need the t hread size due to the fact I'll be getting SPEED BLEEDERS</TD></TR></TABLE>...And the Odyssey is 11mm.
Run a 8 X 1.25 bolt in the caliper. If it fits, there you go.
Old Oct 14, 2003 | 08:40 AM
Witty's Avatar
Default Re: Brake Bleeder Screw HELP...need size.. (AngryTroll)
Call Speed Bleeders. They should know already.
Old Oct 14, 2003 | 08:45 AM
Default Re: Brake Bleeder Screw HELP...need size.. (Witty)
T hanks guys...already found it.!!!!
Ransom
Apr 17, 2007 04:16 PM
Racermech
Mar 29, 2005 10:24 AM
pgpunkguy
Jul 27, 2004 02:55 AM
noah
Mar 24, 2004 01:52 PM
SlopeSurfer
Jun 28, 2002 07:37 AM
