dowel pins for ls/vtec. how does it work?
Old Oct 13, 2003 | 06:58 AM
SpeedMonkeyRacing's Avatar
Default dowel pins for ls/vtec. how does it work?
like the title says. i know it comes with 2 pins but how exactly do they work? i mean don't you have to cap the origial hole where the oil goes through and tap another one?
Jeff-
Old Oct 13, 2003 | 12:20 PM
whiteyg2rs's Avatar
Default Re: dowel pins for ls/vtec. how does it work? (JustJeff)
The dowel pins go where the head studs are. Neither the ones on the LS block or the vtec head will work. You can either have the holes opened up a little to give room for the pins, leave them off and risk having an oil leak, or get dowel pins that fit both the head and the block. I did #3. I used a lathe and made some pins out of aluminum for me and some friends.
Old Oct 13, 2003 | 12:34 PM
Default Re: dowel pins for ls/vtec. how does it work? (whiteyg2rs)
well, so how come golden eagle and z10 both are so highly on those?
Jeff-
Old Oct 13, 2003 | 01:35 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustJeff &raquo;</TD></TR><TR><TD CLASS="quote">well, so how come golden eagle and z10 both are so highly on those?
Jeff-</TD></TR></TABLE>
Old Oct 13, 2003 | 01:48 PM
Default Re: dowel pins for ls/vtec. how does it work? (Vetter)
i meant to say...am i better off take it to the machine shop and have 'em weld and drill new hole on the head since the pin doesn't fit well?
Jeff-
Old Oct 13, 2003 | 01:53 PM
untitled's Avatar
they dont weld anything. i just had them bore the two rear(i think) dowel pin holes ou to 14mm and i just used those two. here:
http://www.c-speedracing.com
they did a lsvtec and a crvtec buildup which is the same thing. goto their how-to section to see it. it will help alot. they cover everything.
Old Oct 13, 2003 | 02:43 PM
DIY_Racing's Avatar
http://www.diyracing.com
Click ls vtec how to...
pakn-heat
Dec 1, 2009 04:17 PM
bOOsT-FeIn
Aug 30, 2006 09:15 PM
TurboCoop
Jul 1, 2005 05:06 PM
B16Civic93
Dec 27, 2004 04:20 AM
Propulsion
Jul 14, 2003 02:13 PM
