A/c belt removal?
Old Oct 12, 2003 | 08:46 PM
hybridEj6's Avatar
Default A/c belt removal?
is it possible to take off my a/c belt for the dyno and then put it back on without getting a new belt.....could i take it off and put it on without strethching it too much? Ive heard of people taking the belts off powersteering and putting them back on but i dont have p/s so
Old Oct 12, 2003 | 10:09 PM
Brad's Avatar
Yes, I re-installed the same belts(alt, a/c,ps) when I did my timing belt and it worked fine.
Old Oct 12, 2003 | 10:28 PM
hybridEj6's Avatar
Default Re: (Brad)
can i adjust the tension on the p54bracket (b18c in civic)to make it easier to take off the belt right?
Old Oct 12, 2003 | 11:05 PM
Rob Dizzle's Avatar
Default Re: (ekhybrd)
im pretty darn sure that you wont loose any power with the a/c belt on becuase the a/c compressor isnt even being used.
the power steering pump is always on though. u can gain a couple whp from removing that belt
Old Oct 13, 2003 | 12:36 AM
hybridEj6's Avatar
Default Re: (Bob-DC2)
are you sure im shure there is more parasitic drag the crank has one more pulley to turn....abviously its not going to be the same as having your a/c on vs a/c off
Old Oct 13, 2003 | 05:15 AM
IN VTEC's Avatar
Default Re: A/c belt removal? (ekhybrd)
On B-series motors, you have to partially drop the driver-side lower engine mount to get the belt out, or you can just cut the belt and put a new one on later.
aznromeo4u
Feb 18, 2015 07:51 PM
v1crattlehead
Sep 12, 2009 12:38 PM
J9D6M
Jul 13, 2006 06:28 AM
Shaun
Feb 22, 2006 10:24 AM
vinuneuro
Oct 7, 2005 09:11 PM
