enigne question
Old Oct 12, 2003 | 02:03 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default enigne question
99 b16a in 96 hatch obd1 harness.
drove it around with open header cause the exaust doesnt
bolt up to the header. the car seems to be kinda jumpy, its only throwing one
code for 02, and the idle is at 1500 and it jumps its not a steady idle. any
ideas what it could be?
Old Oct 12, 2003 | 07:17 PM
Quiks66's Avatar
Default Re: enigne question (ruthlessbucket)
You should check to see if you have a vacuum leak. Even the smallest crack in your intake manifold gasket can cause your engine to 'bounce' when idling. Feel lucky that you only tripped one check engine code!
1998_4dr_gsr
Oct 27, 2006 03:21 PM
c0nspire
Feb 23, 2006 02:09 PM
jumpmann23
Oct 13, 2003 02:59 PM
intekragsr
May 22, 2003 03:32 AM
Prevail
Feb 28, 2003 07:19 AM
