Help ECU code 10 O2 sensor..
I've done he mini me swap and am tryin to clear some codes... im getting one long blink and a space epeatedly. i assume this is code 10.
the o2 sensor had 2 black wires (heating element i assume) and a green and white wire...
The white wire is the od data.. the green? ground possibly?
and the black are + and neg on the o2 sensor.
im runnin one black wire to the yello/black wire from the injectors.. which is + and the other bloack wire back to the ECU
and the white wire is hooked up to the o2 sensor...
Any help if im wrong and what to do with the green wire is appreciated!
-x m d
-x m d
Driven
11
Aug 30, 2004 08:35 PM
Heres how to wire a 4 wire o2 sensor on a car that uses a single wire
