GM Syncromesh, regular or friction modified?
Old Oct 12, 2003 | 09:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default GM Syncromesh, regular or friction modified?
I'm thinking of trying some synchromesh tranny fluid here in a couple weeks, since my friend who works at a Chevy dealer can get it for $5/qt.
I'm wondering should I get the friction modified stuff or just the regular? I read over in the ITR forum that alot of them are using the FM, but do they need that because of the LSD? Would the FM stuff be alright to use in a open-diff tranny, or do I need to use the regular stuff?
Old Oct 12, 2003 | 10:50 AM
B2FiNiTY's Avatar
Default Re: GM Syncromesh, regular or friction modified? (PatrickGSR94)
Friction modified is a lot better.
Old Oct 12, 2003 | 02:50 PM
fivespeedintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking of trying some synchromesh tranny fluid here in a couple weeks, since my friend who works at a Chevy dealer can get it for $5/qt.
I'm wondering should I get the friction modified stuff or just the regular? I read over in the ITR forum that alot of them are using the FM, but do they need that because of the LSD? Would the FM stuff be alright to use in a open-diff tranny, or do I need to use the regular stuff?</TD></TR></TABLE>
from everything i read before i put the GM stuff in my tranny, it said NOT to get the friction modified one.
just the normal GM stuff here and it's great
Old Oct 12, 2003 | 03:58 PM
patdemps's Avatar
Default Re: GM Syncromesh, regular or friction modified? (fivespeedintegra)
friction modified here for my GSR....i've got an itr tranny and a kaaz lsd though.
its treated my car like gold thus far
Old Oct 12, 2003 | 04:30 PM
Community Builder
Default Re: GM Syncromesh, regular or friction modified? (patdemps)
yeah but I'm asking since I don't have LSD, could I use the FM stuff or would that be a bad idea, or does it not matter?
Old Oct 12, 2003 | 08:21 PM
Community Builder
anyone else?
Old Oct 12, 2003 | 09:09 PM
maxxdout's Avatar
YEs, wait a second ok. they're re 3 types of transmission fluids ie MT fluids. normal, friction modified and highly friction modified. Our transmissions call specifically for highly friction modified fluid. I have looked around and honda MTF isnt that bad right from the dealer...as far as price is concerned. As for the LSd, i cant comment, i know when assembling rear ends additives are added when using certain types of clutch pack style limited slip units. Check with the dealer, i dont know if an additive is added for the itr lsd or not.
Good luck
Old Oct 12, 2003 | 10:00 PM
P1mpSlap's Avatar
I heard it's good to use a little of both.
Check the thread in the Hype Arr forum. It has all you need to know on this subject.
https://honda-tech.com/zerothread?id=620135
Old Oct 13, 2003 | 05:00 AM
Community Builder
Default Re: GM Syncromesh, regular or friction modified? (maxxdout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">Our transmissions call specifically for highly friction modified fluid.</TD></TR></TABLE>
Where are you getting this information?
Old Oct 13, 2003 | 08:41 AM
here....this is what you need.
it's part number 12345349.
Old Oct 13, 2003 | 07:37 PM
maxxdout's Avatar
Where are you getting this information?</TD></TR></TABLE>
honda MTF is highly friction modified fluid
Old Oct 13, 2003 | 08:23 PM
Community Builder
honda MTF is highly friction modified fluid</TD></TR></TABLE>
does it say so on the bottle or something? I'm just wondering...
that's interesting, because I've heard many reports of people using regular GM synchromesh and reporting major improvements over Honda MTF.
Old Oct 13, 2003 | 08:27 PM
P1mpSlap's Avatar
GM synchromesh is about the best stuff you can get.
I know people that no longer complain about their 3rd gear grind b/c they are using it.
Old Oct 14, 2003 | 04:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard many reports of people using regular GM synchromesh and reporting major improvements over Honda MTF.</TD></TR></TABLE>
i love it. every shift is like butter. before, 2nd gear would stick a bit sometimes, and shifts felt notchy. all that is gone....
Old Oct 14, 2003 | 10:08 AM
PupaScoopa's Avatar
So from reading the above, what is the final verdict: friction or not?
Old Oct 14, 2003 | 12:37 PM
tilt's Avatar
Default Re: GM Syncromesh, regular or friction modified? (PupaScoopa)
It's my understanding you should get the friction modified one if you have lsd. Regular for non lsd.
Old Oct 14, 2003 | 03:01 PM
oMek's Avatar
Default Re: GM Syncromesh, regular or friction modified? (tilt)
i just put the friction mod gs syncomesh in my 95 gsr non lsd, its much much smother. and ive only driven it maby 50 miles. i havea 5th gear grind if im over 5k rpms and so far it hasent helped it. im gona go for a long drive and see if it gets any better over the next few weeks
RS'R'
Jan 3, 2007 05:44 PM
blinx9900
Nov 21, 2006 09:04 AM
Libertariat
14
Oct 18, 2006 05:48 PM
litterbox
Feb 11, 2005 06:13 PM
endlessdv
May 29, 2004 10:35 PM
