I'm lossing boost starting at about 5k to 7k
Old Oct 11, 2003 | 09:03 PM
Sinner's Avatar
Default I'm lossing boost starting at about 5k to 7k
I boost to 7 psi then it drops to 5. this happens in 2rd and some in 3rd gear. I just replaced my charge pipes and it still here. I figure next thing I should do is test if the setup can hold pressure. What else could do that? what about exhaust problems?
Old Oct 11, 2003 | 09:38 PM
safe driver's Avatar
Default Re: I'm lossing boost starting at about 5k to 7k (Sinner)
what size exhaust do you have? that could be causing some resistance.
Old Oct 12, 2003 | 07:50 AM
Sinner's Avatar
Default Re: I'm lossing boost starting at about 5k to 7k (safe driver)
my down pipe is very small I'd say 1-7/8". it was made at miduis
Nick
Old Oct 12, 2003 | 08:09 AM
civictypenos's Avatar
that would be the first thing to replace,use 2.5 inch at least.
Old Oct 12, 2003 | 08:54 AM
nevin's Avatar
turbo might be too small also. or wg vaccum isnt from intake manifold and your seeing some intercooler pressure drop. or a boost leak. or a ton of other possibilites. :/
Old Oct 12, 2003 | 10:11 AM
illi Adik's Avatar
Default Re: (nevin)
What is the size of the turbo?
Old Oct 12, 2003 | 10:23 AM
Sinner's Avatar
Default Re: (Jackson4Door)
I should have stated all that info, it used to be in my sig.
d15b (jdm vtec)
td04 greddy turbo and manifold
small shitty downpipe.
greddy type 's' bov
Ford 310cc injectors controlled by fields.
DSM g1 intercooler
Thats a little more info then you needed.
Old Oct 12, 2003 | 10:32 AM
lazerus's Avatar
Default Re: (Sinner)
Try removing the downpipe, and doing a test run.
Old Oct 12, 2003 | 01:39 PM
Sinner's Avatar
Default Re: (lazerus)
good idea. thanks. that would answer the question very easily
Lao17
Apr 30, 2011 08:59 PM
b16g1teg
Jan 1, 2007 12:36 PM
joshcivic00
Jul 25, 2005 01:59 PM
vtec-adykt
Jan 31, 2005 06:07 PM
Starscream
Jul 3, 2003 02:32 AM
