Drag gen 3 fuel pump not working
Old Oct 11, 2003 | 08:43 PM
Cha Shu Bao's Avatar
Default Drag gen 3 fuel pump not working
does anybody have problem with their drag gen 3 in-line fuel pump not working? i dont hear it at all and i've tried to connect it straight to battery.. still no sound.. it does get kinda hot for some reason.. is there somethign wrong with the pump? defective possibly?
Old Oct 11, 2003 | 08:58 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Drag gen 3 fuel pump not working (Cha Shu Bao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cha Shu Bao &raquo;</TD></TR><TR><TD CLASS="quote">does anybody have problem with their drag gen 3 in-line fuel pump not working? i dont hear it at all and i've tried to connect it straight to battery.. still no sound.. it does get kinda hot for some reason.. is there somethign wrong with the pump? defective possibly?</TD></TR></TABLE>
TRASH IT!!!
Old Oct 11, 2003 | 08:59 PM
TurboCX's Avatar
One wire goes connected to the main relay and the other is a ground. Maybe it's not connected right. That pump is quite loud and you should be able to hear it.
Old Oct 11, 2003 | 09:45 PM
666's Avatar
666
Maybe you should qiut renching on your own car and have a qualified mechanic check it.
Old Oct 11, 2003 | 10:00 PM
dasher's Avatar
make sure you complete the circuit when testing the pump on the battery ...Ground the negative terminal on the battery too.
When testing in car make sure you grounded pump to shiny metal and not paint... normally you have to use a little sandpaper on your paint to expose metal.
Old Oct 12, 2003 | 07:30 AM
Default Re: Drag gen 3 fuel pump not working (dasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote">make sure you complete the circuit when testing the pump on the battery ...Ground the negative terminal on the battery too.
When testing in car make sure you grounded pump to shiny metal and not paint... normally you have to use a little sandpaper on your paint to expose metal.</TD></TR></TABLE>
i grounded it straight to the battery and powered straight from the battery just to test it, but it doesn't do anything...
Old Oct 12, 2003 | 07:31 AM
Default Re: Drag gen 3 fuel pump not working (DoanTuTsMaiS00dA!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoanTuTsMaiS00dA! &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you should qiut renching on your own car and have a qualified mechanic check it. </TD></TR></TABLE>
thanks for the helpful feedback
Old Oct 12, 2003 | 07:37 AM
dasher's Avatar
sounds like you have a defective unit.... get it replaced.
Old Oct 12, 2003 | 07:43 AM
yea guess i'll have to. thanks for the tips on the turbo install too. appreciated
Old Oct 12, 2003 | 08:49 AM
luti's Avatar
Did you try running the pump without gas in the lines? You can damage them if you run them dry for any amount of time.
Old Oct 12, 2003 | 05:45 PM
666's Avatar
666
You're quite welcome
Old Oct 12, 2003 | 06:13 PM
Muckman's Avatar
Moderator in Chief
check the plug to the fuel pump for power with a test light. make sure it has power with the ignition ON. check fuses too. pop the stock one back in and see if it primes.
elpiar
May 8, 2005 05:01 AM
Teh_Oven
Feb 24, 2004 05:09 AM
wicx
Apr 1, 2002 02:59 PM
GSRwBOOST
Aug 26, 2001 05:40 PM
