Drag gen 3 fuel pump not working
does anybody have problem with their drag gen 3 in-line fuel pump not working? i dont hear it at all and i've tried to connect it straight to battery.. still no sound.. it does get kinda hot for some reason.. is there somethign wrong with the pump? defective possibly?
i ♥ my honda
Global Mod
Global Mod
Re: Drag gen 3 fuel pump not working (Cha Shu Bao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cha Shu Bao »</TD></TR><TR><TD CLASS="quote">does anybody have problem with their drag gen 3 in-line fuel pump not working? i dont hear it at all and i've tried to connect it straight to battery.. still no sound.. it does get kinda hot for some reason.. is there somethign wrong with the pump? defective possibly?</TD></TR></TABLE>
TRASH IT!!!
TRASH IT!!!
One wire goes connected to the main relay and the other is a ground. Maybe it's not connected right. That pump is quite loud and you should be able to hear it.
make sure you complete the circuit when testing the pump on the battery ...Ground the negative terminal on the battery too.
When testing in car make sure you grounded pump to shiny metal and not paint... normally you have to use a little sandpaper on your paint to expose metal.
Re: Drag gen 3 fuel pump not working (dasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher »</TD></TR><TR><TD CLASS="quote">make sure you complete the circuit when testing the pump on the battery ...Ground the negative terminal on the battery too.
When testing in car make sure you grounded pump to shiny metal and not paint... normally you have to use a little sandpaper on your paint to expose metal.</TD></TR></TABLE>
i grounded it straight to the battery and powered straight from the battery just to test it, but it doesn't do anything...
Re: Drag gen 3 fuel pump not working (DoanTuTsMaiS00dA!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoanTuTsMaiS00dA! »</TD></TR><TR><TD CLASS="quote">Maybe you should qiut renching on your own car and have a qualified mechanic check it. </TD></TR></TABLE>
thanks for the helpful feedback
Did you try running the pump without gas in the lines? You can damage them if you run them dry for any amount of time.
wicx
04-01-2002 02:59 PM
GSRwBOOST
08-26-2001 05:40 PM
