Removing pulley
What is the best way to remove the nut on the crankshaft pulley. Also is it reverse threaded? Right now i am using a pipe wrech to hold the pulley in place and i'm trying to loosen the nut normally. Is there a better way, such as an impact gun? And also just wanted to make sure the threads are normal.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by florduhdude »</TD></TR><TR><TD CLASS="quote">A good air impact and luck</TD></TR></TABLE>
luck?
luck?
http://www.amazon.com/Powerbuilt-648..._ob_hi_title_0
The ONLY way a crank pully bolt should be removed.
fminusmic
Jun 18, 2018 02:22 PM
jodyboy
13
Jul 1, 2012 11:52 AM
Ri5e
Mar 16, 2002 12:19 AM
