brake drum
Old Oct 10, 2003 | 10:31 PM
CeoStatus0's Avatar
Default brake drum
i have a 98 civic.. i painted my rear brake drums.. i want to strip the paint, is there something i should use for it.. or would aircraft stripper to powerful for it?
Old Oct 10, 2003 | 11:31 PM
Stripped Honda's Avatar
99-0104
Default Re: brake drum (pureaznxex)
aircraft will work then just paint them semi-gloss black and it will look non rice anymore
Old Oct 11, 2003 | 12:13 AM
Quik Chris's Avatar
Default Re: brake drum (Stripped Honda)
aircraft stripper for sure. The name makes it sound all powerfull, but the chemical is just a way of braking down the paint, it's not a caustic base or acid or anything. If you get it on your skin, it's not going to burn you. So it will be fine to use on your drums.
Old Oct 12, 2003 | 12:23 AM
CeoStatus0's Avatar
Default Re: brake drum (Quik Chris)
thanks guys.. i just wanted to double check before i did it because my homeboy said i have to becareful depending on what material the drum is made out of
tpot90
Dec 9, 2007 05:42 PM
jfastman
May 18, 2004 03:17 PM
phantom_sol
22
Apr 5, 2004 11:48 AM
slope00
Jun 28, 2002 10:30 PM
AK94GSR
Jun 22, 2001 11:58 AM
