r/s ratio on a b20
Old Oct 10, 2003 | 04:39 PM
davken1102's Avatar
Default r/s ratio on a b20
does anyone know the r/s on a b20 block?
Old Oct 10, 2003 | 04:40 PM
GSRswapandslow
Guest
Posts: n/a
1.54 i believe
Old Oct 10, 2003 | 04:46 PM
davken1102's Avatar
Default Re: (GSRswapandslow)
damn that sucks! i was hopin it would be more around 1.65:1
Old Oct 10, 2003 | 07:14 PM
slammed_93_hatch's Avatar
Default Re: r/s ratio on a b20 (davken1102)
The ideal R/S is 1.75:1,
B16A:
Rod length: 134 mm
Stroke: 77 mm
R/S: 1.74:1
Displacement: 1587.12 cc
B17A:
rod length: 131.87 mm
Stroke: 81.4 mm
R/S: 1.62:1
Displacement: 1677.81 cc
B18A-B:
Rod length: 137mm
Stroke: 89mm
R/S: 1.54:1
Displacement: 1834.47 cc
B18C:
Rod length: 137.9 mm
Stroke: 87.2 mm
R/S: 1.58:1
Displacement: 1797.36 cc
B20A (Older Prelude Si)
Rod length: 141.7-142.75 mm
Stroke: 95 mm
R/S: 1.49-1.50:1
Displacement: 1958.14-2056.03 cc
Old Oct 10, 2003 | 08:15 PM
davken1102's Avatar
Default Re: r/s ratio on a b20 (slammed_93_hatch)
yea, i knew the ideal ratio was 1.75:1 but i really doubted that a b20 block out of a CR-V would be close to that but 1.54 is pretty far off so you wouldnt be able to rev it up very high. which sucks
Old Oct 10, 2003 | 08:23 PM
GSRswapandslow
Guest
Posts: n/a
you can rev it as high as you NEED to.
it's all in the cams and the setup. supre high revs aren't needed unless you make power super high.
vtecfed
Feb 12, 2005 06:06 PM
Dan GSR
Mar 27, 2003 02:15 PM
Regular Series
May 23, 2002 10:37 AM
Kamin
May 10, 2002 08:45 AM
617arg
Jul 13, 2001 11:05 AM
