Injector size....is stock enough?
Old Oct 10, 2003 | 03:33 PM
split's Avatar
Default Injector size....is stock enough?
Ok I searched and read this https://honda-tech.com/zerothread?id=520883
But what I would like to know is will I need to upgrade my injectors or will the stock gsr be enough? the setup in an 01 gsr:
b18c
skunk stage 2 cams/valvetrain
cam gears
skunk intake mani
4-2-1 header
I am already running the cams and using hondata w p72 ecu.....without problems, I need to upgrade my exhaust. Open header I made ~170whp. I am asking if after I install the pistons will I need to upgrade the fuel system(injectors mainly)
~11.8:1 pistons(not yet installed)
Modified by split at 1:13 AM 10/11/2003
Modified by split at 11:20 PM 10/31/2003
Modified by split at 11:21 PM 10/31/2003
Old Oct 10, 2003 | 03:37 PM
chrisCNL's Avatar
Default Re: Injector size....is stock enough? (split)
if you are ready using or trying to use skunk 2 cams you need to get your fuel system upgrade. that means new or more flowing injectors, fuel pump, fuel rail, and regulator. stock GS-R injector will not support the motor at all.
Old Oct 10, 2003 | 03:41 PM
DA6GSR's Avatar
Let me put it to you this way. You ever try and blow spitballs with a straw that only lets a small amount of air through? Just doesnt work does it. You will need to let in more fuel. I.E. larger injectors.
-KangaRod-'s Avatar
Default Re: Injector size....is stock enough? (chrisCNL)
If you are upgrading compression and cams (I'm assuming IM and Header too), and changing to a standalone like Hondata, why not upgrade the injectors?
Its almost necessary with all the options you're thinking about to at least go to a 310.
Old Oct 10, 2003 | 03:44 PM
split's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL &raquo;</TD></TR><TR><TD CLASS="quote">if you are ready using or trying to use skunk @ cams you need to get your fuel system upgrade. that means new or more flowing injectors, fuel pump, fuel rail, and regulator. stock GS-R injector will not support the motor at all.</TD></TR></TABLE>
What? if you don't know don't try and sound smart, **** If I don't know I don't post and I will tell you I don't know...
I am already running the cams and only using a vafc.....without problems, I am asking if after I install the pistons will I need to upgrade the fuel system(injectors mainly)
Old Oct 10, 2003 | 03:53 PM
chrisCNL's Avatar
i would prefer you to upgrade to a higher flowing injector. i've tried it with a more of a higher compressor motor and it runs shiety high end. using the VAFC is just stressing the duty cycle of your stock injectors. i.e. any duty cycle above 80 percent will not be good especially on stock injectors.
Old Oct 10, 2003 | 04:18 PM
mts20k97's Avatar
I would go with some 310cc. Maybe bigger if you want to plan ahead.
Old Oct 10, 2003 | 04:25 PM
C_A_T's Avatar
Since there are no idle issues with large injectors when using a Hondata or other programmable engine management, just get big injectors. 370 or 440cc will be sufficient for any street car's all motor needs and their prices are very close to 310s or 270s (worthless).
C_A_T
Old Oct 10, 2003 | 04:33 PM
Rob Dizzle's Avatar
Default Re: (C_A_T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_A_T &raquo;</TD></TR><TR><TD CLASS="quote">Since there are no idle issues with large injectors when using a Hondata or other programmable engine management, just get big injectors. 370 or 440cc will be sufficient for any street car's all motor needs and their prices are very close to 310s or 270s (worthless).
C_A_T</TD></TR></TABLE>
ditto
you will blow up your engine most likely if you drive hard alot with anything above 180whp and stock injectors
its too damn lean
Old Oct 10, 2003 | 04:53 PM
split's Avatar
Default Re: (Bob-DC2)
thanks for the responses, I still would like to know what I need to modify in order to use 310's 440's etc...
Old Oct 10, 2003 | 09:51 PM
AussieK24's Avatar
Default Re: (split)
Yeah I found that 180whp was the limit with stock injectors
Old Oct 31, 2003 | 01:56 PM
split's Avatar
Default Re: (C_A_T)
So you think 310's are worthless? after I installed hondata, I made ~170 whp and 122wtq stock fuel pressure, stock injectors and above listed mods
I'm looking to buy a used set so I started looking on RC's site using their cc calculator and it looks like they will only support up to 190 @ 80% duty cycle.
is this correct? here is the calculator http://www.rceng.com/technical.htm#WORKSHEET
I'm hoping to make ~200 at the wheels once I raise teh compression.
Any help would be greatly appreciated.
Old Oct 31, 2003 | 02:09 PM
Rob Dizzle's Avatar
Default Re: (split)
wiht ~175-180whp i was at 80% duty cycle @ wot with rc310ss (which are for sale btw)
310s should be good for 190 or so, but i would always prefer to run a bigger injector. if the injector is getting near maxed out u can loose power
Old Oct 31, 2003 | 03:35 PM
shant's Avatar
i know i need injectors but i made 197 peak whp @ 9000rpm with stock 240cc injectors @ 55 psi with vacume off. i used safc to tune.
kulo
Jul 1, 2014 04:42 PM
negusjuda
Feb 6, 2010 01:42 PM
SOHC_4dr
Jul 3, 2006 01:15 PM
type_r_jon
Mar 15, 2006 01:08 PM
na200whp
Mar 4, 2003 04:02 AM
