how do i install my oil catch can?
Old Oct 9, 2003 | 06:29 PM
graphic's Avatar
Default how do i install my oil catch can?
it is a greddy..which hose goes to what???
(98 turbo lude) if this helps!
Old Oct 9, 2003 | 06:36 PM
Poop111444's Avatar
Default Re: how do i install my oil catch can? (graphic)
There is an article atthe "How-to" section at http://www.c-speedracing.com
Old Oct 9, 2003 | 06:37 PM
ATS*Mark's Avatar
OG triple OG
take the hose comming from the valve cover and hook the hose to the catch can , then cap the fitting that the hose originally went on
Old Oct 9, 2003 | 06:50 PM
graphic's Avatar
Default Re: how do i install my oil catch can? (TURSpoonEK)
thanks!
Old Oct 9, 2003 | 08:33 PM
delslow94's Avatar
if u want to run off of the pvc valve u must have a constant vaccum source so instead of running the tubing back to the manifold run it to a preturbo pipe...aka where the filter goes. this way u have the vaccum to keep the pvc open and filter out that oil thats flying around and creating pressure. thats what i will be doing this weekend.
Old Oct 9, 2003 | 08:36 PM
graphic's Avatar
Default Re: how do i install my oil catch can? (delslow94)
then where does the hose the currently connects to the pvc valve go...will i have to plug this up???
EHracer06
12
May 27, 2009 09:31 AM
D21X
Oct 12, 2003 08:37 PM
supergreenNA1
Jul 16, 2002 03:20 PM
uneekcrx
May 18, 2002 07:53 AM
