How To Install a Oil Catch Can?
I'm not sure where the pcv is located on my intake manifold,
that I run to the Oil Catch Can
Anyone have pix or better yet a How-To?
What size hose do I use?
I feel like a newb lol.
Re: How To Install a Oil Catch Can?
https://honda-tech.com/forums/forced-induction-16/official-crankcase-evacuation-thread-turbo-hondas-pcv-catchcan-1199935/
https://honda-tech.com/forums/showth...=catch+can+oil
take your pick. and there is MORE IF YOU SEARCH
You know that breather hose that goes from the intake pipe to the valve cover...? I think they just replace that hose with one that has a filter in the middle.
This shows a lil better.. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-civic-d16z6-pcv-valve-location-pic-2438600/
All you gotta do is search.. it's very simple
thx guys
so I run the hose from the PCV to the catch can along with valve cover vent hose? what do I do about the plug in on the intake manifold?
Hi I'm too at the moment installing catchcan. I read a DIY article about the catchcan setup on the back of the Honda B20 block. I have the Honda fittings, but I think they are too heavy to be aluminum. Will there be a problem when the engine heats up end there is heat expansion - both the block and fittings? If they are different alloys? I attached a image of what I have from the local Honda dealer. Second question is about the washers - they really seem to be aluminum (very lightweight) - should I use them as is (only crush them when screwing) or there is need to apply some teflon tape?
The fittings:
The washers:
The fittings:
The washers:
There's about a million different ways you can go about it
i have a hose from my crancase and valve cover going to a vented can.
but you could also use a vacuum pump.. exhaust slash cut,intake slashcut to pull vacuum in a non vented can etc etc.
The fittings:
The washers:
The fittings:
The washers:
And as far as them being 2 different materials and heating up. I would not worry too much about that. The plugs that are in there now are not aluminum either.
supergreenNA1
07-16-2002 03:20 PM
