Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!!
Old Oct 9, 2003 | 03:43 PM
Boostfed's Avatar
New User
Default Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!!
Well if anyone looked at my other post about me getting a rev limiter at 4800-5000 rpm after running the car hard and boosting. https://honda-tech.com/zerothread?id=637265 Well we went into my current ROM and changed one BAD SPOT in my fuel BUT this did not correct the problem. DOH! Well we FINALLY changed out the Blue Box and I boosted hard up to 9000rpm in 2nd,3rd gear and part of 4th gear hitting about 15psi, Unforunatley we were unable to datalog since this particular blue box does not have the Hondalogger option . Well I did the runs over and over and over again and NOTHING no boost cut no rev limiter NOTHING! Thank God! We did change the Blue Box and the Ribbon at the same time but are pretty POSITIVE it is the Blue box and not the ribbon. Will do some testing on that as well. Could not see it being the ribbon since when it happens we turn the car off and restart it and problem was solved previously until we boosted hard again. I will post more results with swapping the ribbon out to test that out also. Thanks for everyones input on my problem. FYI this is the first time actually since my car made 581.9whp and 381 ft-lb torque but that was at 28psi, I am running 15psi and that is about 400whp AND IT FEEL'S GOOD!!!!!!!!
Old Oct 9, 2003 | 04:45 PM
Mase's Avatar
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (Boostfed)
glad its fixed, but too bad you're still gay
Old Oct 9, 2003 | 04:47 PM
Rhman19's Avatar
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">glad its fixed, but too bad you're still gay </TD></TR></TABLE>
Old Oct 9, 2003 | 06:39 PM
g2turbo's Avatar
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (Rhman19)
good to hear
Old Oct 9, 2003 | 06:46 PM
alpha's Avatar
About damn time! Good to hear man. Must of felt so good to have that problem gone.
Old Oct 9, 2003 | 08:55 PM
Boostfed's Avatar
New User
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (0x64)
YIPPEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Boostfed BOOST! Boostfed to REV TO 9k!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 10, 2003 | 12:12 AM
Full-Race Javier's Avatar
Old Oct 10, 2003 | 12:24 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (javierb14)
I'll tell fredo you are happy.
Old Oct 10, 2003 | 12:30 AM
Boostfed's Avatar
New User
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I'll tell fredo you are happy. </TD></TR></TABLE>
He has something for your PIEHOLE! LOL! =ART
Old Oct 10, 2003 | 02:11 AM
Boost2NA's Avatar
Congrats Terry. Im glad to see you fixed the problem. Hopefully all of the little gremlins are out of the car. You need to get some track times posted up you 10 second *****!!!!!!
Old Oct 10, 2003 | 02:21 AM
integra_gsr98's Avatar
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (Boosted99Si)
Hey one thing to check if you get bored one day and wanna **** with your old blue box...
Check and see what the LED is doing as you drive it. See if it stays solid red or flashes. That's how I found out my ribbon was bad, but the same symptoms will pop up if the blue box is junk as well.
Well have someone with you at least... looking over @ a box while beating the **** out of a 500+ whp car is a little insane and dangerous...
Old Oct 10, 2003 | 03:28 AM
ekb18c's Avatar
wooo hooooooo!!!
Old Oct 10, 2003 | 03:41 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted99Si &raquo;</TD></TR><TR><TD CLASS="quote"> You need to get some track times posted up you 10 second *****!!!!!! </TD></TR></TABLE>
Hes only an 11.9 ***** for the time being.
Old Oct 10, 2003 | 11:04 AM
BodyKits NW's Avatar
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (SIXTYdashONE)
If you do have a problem with your Blue Box will hondata fix it? Are they good at backing up there product?
Old Oct 10, 2003 | 11:47 AM
Boostfed's Avatar
New User
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">If you do have a problem with your Blue Box will hondata fix it? Are they good at backing up there product? </TD></TR></TABLE>
I called today and talked to the girl who answered the phone and she said to send it back with a note explaining the problem and my contact info and they would take it from there.
Old Oct 10, 2003 | 02:06 PM
THE BEAST's Avatar
Cool Man....I got my bitch running this week too!!!
Old Oct 10, 2003 | 10:43 PM
Boostfed's Avatar
New User
Default Re: Fixed my Rev Limiter PROBLEM with Hondata!!!!!!!!!!!!!!!! (THE BEAST)
Cool maybe I will sytop by tomorrow and check it out! Gotta see the new paint job! Get sleeves yet?
Old Oct 21, 2003 | 09:42 AM
sung's Avatar
that blue box must be special!
Old Oct 21, 2003 | 12:26 PM
PWRVTEC's Avatar
Default Re: (sung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sung &raquo;</TD></TR><TR><TD CLASS="quote">that blue box must be special! </TD></TR></TABLE>
Nah I heard that some asian guy let him borrow it... So it's not special...lol
Chris1521
Mar 11, 2011 06:57 AM
Boostfed
Nov 1, 2003 05:39 AM
Sprockets
Nov 20, 2002 10:47 PM
92HB_HB
Mar 4, 2002 05:51 PM
