No pressure in clutch pedal
Old Oct 9, 2003 | 09:29 AM
RHEMU's Avatar
Default No pressure in clutch pedal
I have no pressure in my clutch pedal. I have a '90 Accord. I have changed the slave cylinder, the clutch pedal, and master cyclinder. What could be wrong???
Old Oct 9, 2003 | 12:45 PM
pogidawgie's Avatar
Default Re: No pressure in clutch pedal (RHEMU)
Did you bleed the lines already?
Old Oct 9, 2003 | 03:36 PM
AngryTroll's Avatar
Default Re: No pressure in clutch pedal (pogidawgie)
Bleed the system again:
Open the bleeder valve on the slave cylinder and let the system gravity bleed for a few minutes.
Shut the valve, have a helper pump the clutch pedal and hold it down (it may be necessary to pull the clutch pedal up by hand).
Crack the bleeder valve open and shut it before the clutch pedal is released. Repeat, repeat, and repeat...It could take awhile. The pedal will slowly but surely build pressure.
Old Oct 9, 2003 | 07:55 PM
ShiftStain
Guest
Posts: n/a
Default Re: No pressure in clutch pedal (AngryTroll)
need the bleedage!
Old Oct 13, 2003 | 05:29 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngryTroll &raquo;</TD></TR><TR><TD CLASS="quote">
When I did mine I don't remember having to bleed the clutch the same as the brakes. I don't have my Helms with me right now but all I think you have to do is open the bleeder valve and pump the clutch pedal until fluid comes out in a solid flow without bubbles while keeping the resivor full. If I'm wrong, sorry. I'll double check my Helms when I get home.
Old Oct 15, 2003 | 11:10 PM
Showoff's Avatar
Default Re: No pressure in clutch pedal (TouringAccord)
guys maybe could help me out out also , i did a swap h22a into an 95 accord and put an clutch master stage 3 with an clutch master flywheel..and time to my clucth picks up really good and sometime feel like its gone do i have the same problem as him ?
Old Oct 16, 2003 | 03:40 AM
H-T Order of Merit
Default Re: No pressure in clutch pedal (Showoff)
What do you mean by "sometime feel like its gone"? Could try and describe this problem a little more.
TheDonOG
Jan 7, 2017 01:37 PM
emgjsdk1
Feb 10, 2011 05:30 AM
924doorEG
Jul 16, 2007 05:31 AM
slwcivic
Jun 25, 2006 05:42 PM
