No Clutch pedal pressure
Old Jun 17, 2006 | 07:19 PM
slwcivic's Avatar
Default No Clutch pedal pressure
Well i installed a aftermarket clutch an flywheel in my 93 civic with a z6 swap..
A friend and I went to bleed the clutch an the pedal will not build up any pressure. after many trys at bleedin it.
I was wondering wat may cause this to happen?
If you need more info jus ask an ill tell ya.
nate
Old Jun 17, 2006 | 08:56 PM
djbutler007's Avatar
Default Re: No Clutch pedal pressure (slwcivic)
a leak in the lines might be it
Old Jun 24, 2006 | 10:09 AM
95Bubble's Avatar
ive bled a couple clutch lines and sometimes it take a while
Old Jun 24, 2006 | 03:27 PM
Gunns's Avatar
Default Re: No Clutch pedal pressure (95Bubble)
If you bleed the clutch line properly and it still doesn't build pressure then you either have a leak in the line or the clutch master cylinder could be bad.
When you bleed do you make sure the master cylinder is always full so that it does not pull air into the lines?
Does a strait stream of fluid come out of the bleeder valve? Or are you still getting air bubbles coming out?
Is the pin at the transmission being lined up properly? (The pin the the fluid pushes)
Old Jun 25, 2006 | 04:30 PM
0618turbocivic's Avatar
bad clutch master cylinder? lines broke? takes while to pump up
Old Jun 25, 2006 | 05:42 PM
1SYKSI's Avatar
Lift up on the clutch pedal manually with the bleeder valve open. press the pedal down and lift manually until pressure starts building, as soon as a steady stream comes out the bleeder valve have a buddy tighten the valve while you keep the clutch depressed.
ducsaim
Jan 14, 2011 12:17 AM
Draggin99Si
Jun 21, 2007 10:23 AM
stock95civic
Mar 12, 2007 10:55 PM
SlowPoke
Nov 25, 2002 09:36 AM
