Which sub is better???
Old Oct 8, 2003 | 02:00 PM
dieselstation's Avatar
Default Which sub is better???
JL 12" W3 v.2 vs. Kicker Solobaric S12L5
JL:
Kicker:
Old Oct 8, 2003 | 03:28 PM
GSteg's Avatar
better for what? whats your goal?
Old Oct 8, 2003 | 05:52 PM
Default Re: (GSteg)
I ended up getting the Solobarics. I talked to 3 friends and 1 person i didn't know and asked them their opinions.. 2 of my friends used to work at a stereo shop, and the the other dude installs systems privately for competition. their opinions were impartial since none of them were trying to sell me anything.. so i trust them.
they all said go with the Kickers. they said that even though this isn't as high end as they would usually buy, it's still better then the W3's (even though the W3's is VERY decent in itself). It didn't really matter which one i got, since they're bot great.. but the solobarics sound better and have a higher rating and perfect for the type of music i'm going to listen to (drum and bass, jungle, breaks, etc..).
so there you have it. now i need to find some decent amps.
Old Oct 9, 2003 | 01:09 AM
Calavera's Avatar
Default Re: (dieselstation)
my friend had a kicker L5 and it hit pretty hard.. it was too tight IMO. JL was more smooth... cant really describe it but I personally like W3 better. But its all preference.
Old Oct 9, 2003 | 03:18 PM
10K2HVN's Avatar
Default Re: Which sub is better??? (dieselstation)
They L7 is suppose to sound really good..better the a W3..but i will never get another kicker product again.
JL's got my vote.
..buts whats your power, ohms, and money range..?
Old Oct 9, 2003 | 03:49 PM
4uhataz's Avatar
The L5 is simply a SPL type of sub. It will get loud and hit hard, but can it sound good doing it? No. If you want more of an SQ sub then the JL is the way to go. If you want SPL then get the L5. The L7 doesn't sound good either, it can just be used in different enclosure applications. A square speaker cannot produce bass as accurate as a round speaker which is whay you never see square component sets, etc..
Old Oct 11, 2003 | 09:52 AM
92Periwinkle's Avatar
Default Re: Which sub is better??? (10K2HVN)
in my personal opinion, the L5, L7 sound dry and hollow. i have 2 12" W3's and they sound awesome. 2 weeks ago I hit 145.5 dB on a music track, didn't even use a test tone. they sound clean and very smooth.
Old Oct 13, 2003 | 03:36 AM
is3oo's Avatar
Default Re: Which sub is better??? (92Periwinkle)
I've got 2 10" JL Audio W3v2's and they sound awesome.
Old Oct 14, 2003 | 10:23 PM
showtymers619's Avatar
* B A N N E D *
Default Re: Which sub is better??? (Type-Rizzle)
shoulda just got a 12w6v2 you would be ALOT happier.. but im guessing its all also based on funds also..listen to a 12w6v2 with a 500/1 jl amp.. in a sealed box.. that thing hits and with the w7 cant compare any kicker sub at all..JL is beyond kicker in every way amp vs amp and speaker vs speaker and the only thing kicker gots on JL is price.. and its not that big of a difference...
Old Oct 16, 2003 | 03:48 PM
mattduskater's Avatar
I would go wit jbl
Old Oct 16, 2003 | 04:23 PM
10K2HVN's Avatar
Nuff Said.
Old Oct 16, 2003 | 11:05 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dieselstation &raquo;</TD></TR><TR><TD CLASS="quote">JL 12" W3 v.2 vs. Kicker Solobaric S12L5
I have a L7 in one ride and a W3v2 in another.
The L7 hits beats more accurately. Much like a 10" versus a 12".
But the W3v2 throws smoother low frequencies. On really low and long frequencies with the L7, you can hear it vibrating back and forth.
They're both good for different types of music. But most of my friends, guys and girls, like the sound of the L7. It hits more accurately at higher frequencies. Its easier to blend beats from the mids to the subs, cuz you can overlap the frequencies.
There's definitely more speaker slap on higher frequencies with the L7 though. I keep the x-over at about 63Hz. On the W3v2's, the x-over's at 80Hz.
Old Oct 17, 2003 | 03:55 AM
acuradriva's Avatar
Default Re: Which sub is better??? (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">
There's definitely more speaker slap on higher frequencies with the L7 though. I keep the x-over at about 63Hz. </TD></TR></TABLE>
Isn't that the opposite of what you just said?
Alot of it is te enclose. L&'s should not sound "hollow". But the jl should sound a little better.
Old Oct 17, 2003 | 04:16 AM
4uhataz's Avatar
Default Re: Which sub is better??? (acuradriva)
It should sound a lot better. If it doesn't then you need to have your system checked. L7's are square speakers. Shapes other than round have been proven to distort bass and be much more inaccurate.
Old Oct 17, 2003 | 05:57 AM
GSteg's Avatar
Default Re: Which sub is better??? (4uhataz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4uhataz &raquo;</TD></TR><TR><TD CLASS="quote">It should sound a lot better. If it doesn't then you need to have your system checked. L7's are square speakers. Shapes other than round have been proven to distort bass and be much more inaccurate.</TD></TR></TABLE>
believe it or not, the L7 has won SQ comps. its amazing what EQ's can do. not to mention the time put into the installation.
Old Oct 17, 2003 | 11:09 AM
rodimus's Avatar
Default Re: Which sub is better??? (GSteg)
JL Audio....or
L7....
or....................
W7???
Old Oct 17, 2003 | 11:56 AM
10K2HVN's Avatar
Default Re: Which sub is better??? (EVOL)
guess its not enough said...
http://www.termpro.com/cgi-bin...15607
whoa..my 1700th post!
..i would also just like to add..ZeroForum is the best!
Modified by 10K2HVN at 1:20 PM 10/17/2003
Old Oct 19, 2003 | 11:37 PM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva &raquo;</TD></TR><TR><TD CLASS="quote">
Alot of it is te enclose. L&'s should not sound "hollow". But the jl should sound a little better.</TD></TR></TABLE>
The L7 does hit more accurately at higher frequencies but at extreme rapid excursion, they tend to slap more than W3's.
Old Oct 20, 2003 | 09:20 AM
10K2HVN's Avatar
omg somebody shoot me! lets pretend i was never in this thread.
Old Oct 23, 2003 | 11:30 AM
4uhataz's Avatar
What in the world does that mean?
Old Oct 23, 2003 | 02:43 PM
GSteg's Avatar
Default Re: (10K2HVN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">omg somebody shoot me! lets pretend i was never in this thread.</TD></TR></TABLE>
eh?
Old Oct 23, 2003 | 03:07 PM
stockLS's Avatar
Default Re: (GSteg)
i would tell you that you got ripped off and that kickers suck.. but i dont know what you paid for them so i will just tell you this... you really gave us no choice seeing as how the w3 and the l5 both are mediocre subs to begin with.. im not flaming you but depending on what you wanted in the sub the l5 is more for punchy base as where the w3 is more for smooth stroke and a deep note .... imo you should have either gotten the w6 or the titanium series audiobahn.... check http://www.ikesound.com they have good deals at times
Old Oct 25, 2003 | 02:29 AM
Import13alla's Avatar
Default Re: (stockLS)
JL hands down! (check http://www.ikesound.com they have good deals at times) This is true!
lee0149
Audio / Security / Video
Dec 16, 2008 06:17 AM
97dc4 0614
11
Oct 22, 2006 10:03 PM
gimme_h22
Oct 12, 2004 02:09 PM
SilverDc2
May 28, 2003 08:09 PM
vteg
Dec 26, 2002 06:47 PM
