Who's running 85mm bore with boost..
As the topic says! I have a regular golden eagle Gsr block sleeve to 85mm. Is it okay to run high boost levels with this?
It is a little late be asking this now isnt it. You already have it. Yes you should be fine people usually try to stay at a lower bore in case the melt a piston or anything goes wrong so they can bore it out a bit more an work from there. Otherwise you are fine at 85mm it is just gonna suck when something goes wrong. Good luck and happy boosting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance »</TD></TR><TR><TD CLASS="quote">As the topic says! I have a regular golden eagle Gsr block sleeve to 85mm. Is it okay to run high boost levels with this?</TD></TR></TABLE>
I definitely wouldnt............Why did you go 85mm????
Well I have a built motor with toda c's, and a 85mm block with pauter rods and rollerwave pistons. I love my setup, but i'm thinking about moving over to the darkside. Lucky thing that i have a spare gsr block that i can get resleeved. What bore do you recommend? I'm new to all this turbo ****! Any sugestions on what i need to build a 11sec boost gsr engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance »</TD></TR><TR><TD CLASS="quote">Any sugestions on what i need to build a 11sec boost gsr engine?</TD></TR></TABLE>
Yeah, change your cams back to stock, and then win the lotto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance »</TD></TR><TR><TD CLASS="quote">Well I have a built motor with toda c's, and a 85mm block with pauter rods and rollerwave pistons. I love my setup, but i'm thinking about moving over to the darkside. Lucky thing that i have a spare gsr block that i can get resleeved. What bore do you recommend? I'm new to all this turbo ****! Any sugestions on what i need to build a 11sec boost gsr engine?</TD></TR></TABLE>
Take the spare block get it sleeved and bore it to no more than 83mm. I say this because you can still make a little more tq, but you still have room for error. As for the turbo and the rest of your setup just keep around the FI forum or search for different setups.
