Can someone explain.. 13.5 psi & Stock Honda Map Sensor
So yeah. How does it work?
With hondata, I ran 13.5 pounds o' boost on the stock map sensor. The maps looked fine, power was great, no fuel cut, no codes..... the tuner said it was fine... Why is that?
doesn't the honda stock map only read 11.5 psi? I'm confused.
Heh, thanks.
-erik
Heh, thanks.
-erik
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tofurky »</TD></TR><TR><TD CLASS="quote">So yeah. How does it work?
Heh, thanks.
-erik</TD></TR></TABLE>
If I'm not mistaken the stock map sensor is a 2 bar map sensor that can read up to 15lbs, the only issues that it might have is the diaphram? might bust from what I've heard in the past.
Heh, thanks.
i know what u mean. i'm pushing 12 on my stock map, with the s200. however, when u look at your high speed fuel map on the datalog, notice what the furthest collum you end up using is. it ends up being diffrent than what your boost gauge will read most of the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">Ive tested this, and my stock map sensor stopped reading above 11.7 psi. </TD></TR></TABLE>
That's what I've always though/been told/read.
My boost gauge read 13.5, as did the dynopack(was hooked up to a vacuum source)
the map sensor doesnt have to be dead nuts on compared to absolute pressure. it just has to tell the difference between vacuum and WOT, so it is not manufactured / calibrated to do so.
So either I'm not really running 13 lbs of boost? Or I am risking breaking something? I still don't understand exactly.
Thanks.
Thanks.
My boost gauge read 13.5,</TD></TR></TABLE>
what was the absolute boost ?
the guage isnt always what the map sensor sees
i was seein 25 psi and neptune was seeing 20 psi (this was in colorado)
it shouldnt be that far off on socal, but i would go off of absolute, not guage
Damn guys this is an old post. To answer the questions you can run 13psi on a stock map sensor, but you need to tune the last column conservatively. As in tune the last column for 13psi. The map sensor will think you are only at 11.7psi, but if its tuned conservative there then it will work.
If you are not taking the pressure reading close to the ITM, you might be seeing the boost pressure before the change in pressure after the intercooler.
*If I am wrong than disregaurd this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">how do you install the 3 bar map sensor? is it easy?</TD></TR></TABLE>
had it installed with hondata s200b, so i couldnt tell u if it was easy or not without hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoEvoL »</TD></TR><TR><TD CLASS="quote">
had it installed with hondata s200b, so i couldnt tell u if it was easy or not without hondata.</TD></TR></TABLE>it is easy, make sure you solder the connections on the GM weather pack. and do yourself a favor and buy the removla tool should you need to de-pin for some reason
Heh, thanks.
-erik
Heh, thanks.
-erik
You can run over what the map sensor would read for boost but you won't be able to set boost cut and you basically tune the last column as if it's what ever boost your actually running. I definitely wouldn't recommend it because if your wastegate fails and the car goes from 13psi to 20psi there's nothing to save your *** at all. It will lean out and pop your motor. Get a 4 bar and have it tuned safely with a boost cut set. Stock maps are good for anything under about 9psi so you have a little cushion between the boost your running and your fuel cut. I've found most stock map sensors generally only read to about a 10.5-10.7 lbs
B16Civic93
Apr 2, 2005 09:39 AM
Mr. Softee
Mar 25, 2003 07:29 PM
