SERIOUS h22 turbo manifold problem!!!
Old Oct 7, 2003 | 11:52 AM
killa_lude's Avatar
Default SERIOUS h22 turbo manifold problem!!!
heres my problem....i was putting the wastegate on and i didnt have the original scews so i bought some...when i was installing them one of the screw's head broke off and the screw was stuck in the manifold, flush w/ it...so then i figured i would just drill it out and retap it...well i was doing that and then the drill bit broke off into the manifold...well i said **** it and went to the other side...i drilled it out to the size for the tap and while tapping it the tapping bit broke off into the mani....i was extremely pissed off, and left it there to sit....what can i do to retap the 2 holes for the wg??
Old Oct 7, 2003 | 12:04 PM
prelittlelude's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (killa_lude)
wow sounds like you broke a serious amount of stuff, if i were you i would just nut and bolt it. redrill out that tap, and then get some grade 8 hardend nuts and bolts that are the size you need and use that. screw trying to thread the mani. i mean maybe my answer is a bit over simplified, but thats how im gonna do it on my setup
Old Oct 7, 2003 | 01:06 PM
killa_lude's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (prelittlelude)
how would i get to the back to put the nut on for the wastegate?? i'm nut and bolting the dump tube but you cant for the other 2 screws
Old Oct 7, 2003 | 08:23 PM
Function's Avatar
there are shops that specialize in removing, fixing bolts and retaping holes. A lot of the time a machine shop will do this but i was once referred to a specialist that did this specifically .. if your in nor cal i can refer a place.
Old Oct 7, 2003 | 08:26 PM
killa_lude's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (Function)
sweet thanks man
Old Oct 8, 2003 | 06:38 AM
rjr162's Avatar
the other option is get an extractor. All you have to do is drill a small hole, like 3/8" typically, and get he extrator down in there. It's pretty much a long slightly coned drill bit with threads the opposite way. When it starts to "drill" down into the bolt, it grabs on really tight and causes the bolt to spin back out. You can grab one at sears
Old Oct 8, 2003 | 06:41 AM
PrecisionH23a's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (rjr162)
I agree, the extractor is your best bet.
http://www.sears.com/sr/javasr...fko.0
Old Oct 8, 2003 | 07:27 AM
Sephro's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (GudeH23a)
Yeah don't get the shitty kind they sell at places like Home Depot. The ones at HD are round where the drill connects. You get it in there and the chuck can't hold the thing tight enough. The ones at Sears that Gude linked you to have a hex in the middle. Also they have a drill on one side and the extractor on the other. Costs a lot more but much better Quality.
Old Oct 8, 2003 | 09:00 AM
killa_lude's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (Sephro)
thanks guys!!
Old Oct 14, 2003 | 11:24 AM
VRD^don's Avatar
hey peter..i have bolt extractors..
Old Oct 14, 2003 | 11:35 AM
killa_lude's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (sohc_vtec)
naww
Old Oct 24, 2003 | 08:18 PM
Komsomol's Avatar
Dude. Breathe.
Take a day off before you re-attempt your installation.
Old Oct 25, 2003 | 05:08 AM
killa_lude's Avatar
Default Re: SERIOUS h22 turbo manifold problem!!! (8400RPMS)
its all good, theres a machine shop in town, tht going to retap them for me
Old Oct 25, 2003 | 04:49 PM
brads94accord's Avatar
the exact same thing happened to a buddy of mine when he was putting a new manifold on his Talon TSi. the extractor would be your best bet. he took his to a machine shop and the ended up having to do a heli-coil (i beleve thats what its called)
Old Oct 26, 2003 | 06:02 AM
killa_lude's Avatar
Default Re: (brads94accord)
this machine shop says they get people comming in all the time asking them to do weird jobs. they said they could fix my mani no problem
TravisBiggie
Jun 23, 2012 01:30 AM
dartonh22
Welding / Fabrication
10
Jul 29, 2008 12:02 PM
z6
Aug 15, 2004 03:25 PM
JDubya
Apr 8, 2004 08:01 AM
MugenSi00
Mar 13, 2002 11:39 AM
