anyone riding on HP or GR-2 ?
Old Oct 7, 2003 | 08:32 AM
exr_pd's Avatar
Default anyone riding on HP or GR-2 ?
i have a 94 coupe, with coilovers lowered about 2.5 inches! would either one of these shocks reduce my bounce???? i'm curious cuz i can get a smokin deal on either set, but not a great deal on the adjustables
Old Oct 7, 2003 | 09:46 AM
whoa its len 2's Avatar
Tokico blues and Gr-2's wont last long with a 2.5 inch drop. Id save a little more and look into a better set of shocks.
Old Oct 7, 2003 | 10:43 AM
Neldawg's Avatar
Default Re: (whoaitslen2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoaitslen2 &raquo;</TD></TR><TR><TD CLASS="quote">Tokico blues and Gr-2's wont last long with a 2.5 inch drop. Id save a little more and look into a better set of shocks.</TD></TR></TABLE>
Hi
I was looking to get a set of either one of those shocks.....which would you think would work great with stock springs.....I'm not really looking to drop my car again....not worth the trouble driving in NY.......damn potholes
thanks in advance
Old Oct 7, 2003 | 10:45 AM
Neldawg's Avatar
Default Re: anyone riding on HP or GR-2 ? (exr_pd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exr_pd &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 coupe, with coilovers lowered about 2.5 inches! would either one of these shocks reduce my bounce???? i'm curious cuz i can get a smokin deal on either set, but not a great deal on the adjustables</TD></TR></TABLE>
I would say go for the tokico blues......i had em on my accord wit 1.75 drop....they worked great.....if those 2 were your only choices ....go for the tokicos...if not save up for better ones....its def worth the investment
Old Oct 7, 2003 | 10:54 AM
Crono139's Avatar
KYB AGX.
Old Oct 7, 2003 | 12:47 PM
v4lu3s's Avatar
RTFM
the gr2 is a great oem replacement shock.
i would not use them for anything BUT replacing blown stock shocks.
Old Oct 7, 2003 | 02:03 PM
spankey167's Avatar
Default Re: (v4lu3s)
Any shock will blow very quickly on a 2.5" drop... Yes it will work for a while, but will blow out very quickly because there is no room for the strut/shock to expand and contract much. The shocks will just start bottoming out. One of my friends had KYB AGX on his car... Blew them up in about 3 months with a low drop... My advice is either buy a true coilover system or raise your car to around 1.75". So that the shock can do its work and wont blow out so quickly.
Old Oct 7, 2003 | 06:00 PM
v4lu3s's Avatar
RTFM
tokico illuminas or koni yellows can handle the 2.5 inch drop jsut fine, even blues will do better, i know for a fact that kyb suggests NOT droppiong past 2 inches with the agx.
Old Oct 8, 2003 | 05:00 AM
KGAccord's Avatar
get Koni yellows those are your best bet. if you want to be dropped that low and want a good ride you have to pay either get koni yellows or get real coilovers like teins.
btw, what sleeve type coilovers are you using anyways. most have very high spring rates, except for Ground control is probably the best sleeve type coilovers.
Old Oct 8, 2003 | 02:07 PM
exr_pd's Avatar
i'm riding on stage 1 tom motorsports. there almost identical to the ground controls. (iodized sleeve, single adjustable lock ring w/ locking hex bolt) they feel alot like ground controls too cuz my buddys riding on a set of ground controls. and there coilovers so its linear spring rate not progressive. i'm picking up a set of kyb agx's on saturday, those should help a bunch! anyone riding on kyb agx's?
Mikes2000civicsi
30
Dec 30, 2006 10:12 PM
CHONCH
Oct 17, 2005 12:11 AM
CsiRUN
Sep 5, 2005 07:13 PM
jokr78
Mar 15, 2005 05:13 AM
