Heating system isn't heating up that good
Lotsa possibilities...
If your temperature gauge is reading normal, then look for a broken/disconnected cable from your control lever to the heater valve, air bubbles in your heater core, or even a kinked heater hose in the engine compartment. Maybe corrosion/crud in your heater core, but then it would probably be in your radiator too (causing overheating).
If your temperature gauge is reading real cool, the thermostat might be stuck open. So the coolant never gets hot.
dantamparacer
Aug 5, 2010 06:51 PM
nucrxowner
Jan 18, 2005 12:52 PM
