idle probs
Old Oct 6, 2003 | 02:56 AM
neil-vtec's Avatar
Default idle probs
ive got a uk spec eg6 with a b16a2 with very irratic idle it all started after my water pump died so got a new one in but ever since my warm idle has been over 2000 and closer to 3000 at cold and recently its started alternating between 1 and 2ooo, ive checked my ecu wiring and all seems good.
any help you can offer will be a bonus
thanks in advance
neil
Old Oct 6, 2003 | 03:36 AM
SLOAZZ95's Avatar
Default Re: idle probs (neil-vtec)
idal air control valve, or throttle position sensor. that is what my guess would be.
Old Oct 6, 2003 | 03:51 AM
neil-vtec's Avatar
Default Re: idle probs (SLOAZZ94)
would that not throw up a code though?
Old Oct 6, 2003 | 05:35 AM
SLOAZZ95's Avatar
Not nessarily, i had the same prob at cold idal, and it didnt through a code.
Old Oct 6, 2003 | 06:23 AM
Mike_C's Avatar
is it surging or just too high? you can adjust the throttle cable if it's steadily high.
Old Oct 7, 2003 | 03:43 AM
neil-vtec's Avatar
Default Re: (JMU1337)
tried adjusting throttle cable but still same it is revving around 3 when cold but even when warm it will rev from 1000 to 2500 and then after a couple of minutes hold steady at 1900 but as soon as i drive anywhere again itll start revvin?
I also tried to have a go at my iacv but i really no little about this so any guidance is great
thanks
neil
20vt_gtx
14
Dec 27, 2019 04:50 AM
jlmJDM18
Feb 3, 2014 10:54 AM
maitlenclan
Nov 9, 2013 04:27 PM
95civic16
Jul 20, 2008 05:44 PM
99GreenEX
12
Feb 22, 2008 09:54 AM
