What do you guys think of the SC50 on a d16?
Old Oct 5, 2003 | 09:14 PM
Jkan2001's Avatar
Default What do you guys think of the SC50 on a d16?
I have the apexi ball bearing kit on my 00 ex coupe right now. It made 176/173 whp on 8 psi and i'm wanting to upgrade to something bigger. What do you guys think of the precision SC50 and a revhard manifold? Is this turbo entirely too big for my setup? Also is the SC50 the smallest precision turbo available? I heard someone on the board was running 12's on this turbo with a stock d16 motor.
Any suggestions/comments are welcome, thanks!
Old Oct 5, 2003 | 09:28 PM
DIRep972's Avatar
Smarter than you
Default Re: What do you guys think of the SC50 on a d16? (Jkan2001)
check under username- TurbodCX
fastest sohc turbo street car i know of. i believe hes running a 50 trim.
heres a few of his posts.
https://honda-tech.com/zerothread?id=568933
https://honda-tech.com/zerothread?id=467523
Old Oct 5, 2003 | 10:18 PM
BoostedED9's Avatar
Default Re: What do you guys think of the SC50 on a d16? (DIRep972)
i ran the sc50 on my sohc setup and worked great.... the car was street driven just not that much since it had no insurance
Old Oct 6, 2003 | 04:09 AM
TurbodCX's Avatar
Thanks bro!
Actually i am using a .60 trim T04E with a .63 exhaust side.
I think with the SC50 you will make good power also.
Brian
Old Oct 6, 2003 | 02:05 PM
Jkan2001's Avatar
Default Re: What do you guys think of the SC50 on a d16? (TurbodCX)
What are the spool times like? I'm only going to run about 6-8 psi on the AFC hack temporarily till i can put together a built motor and run hondata or try the uberchip setup. What kind of power can be expected and do you think the AFC hack won't be sufficient for the boost levels i'm looking for?
I made 176/173 on the APEXi kit with the IHI P18 turbo (about the size of a 16G but ball bearing)
Thanks for the advice, You're my sohc turbo hero
Old Oct 6, 2003 | 02:06 PM
Jkan2001's Avatar
Default Re: What do you guys think of the SC50 on a d16? (BoostedED9)
How did you run 16 pounds on a stock internal D16Z6? Is that just with a blockguard and a thicker headgasket or something? I'd be more than happy to make 220 whp with the SC50, which manifold did you guys run on the SOHC with your SC50's and where can i get the manifold/downpipe?
If i'm not mistaken the SC50 is the smallest precision turbo, would the SC34 be too big for street driving on low boost?
Old Oct 6, 2003 | 02:15 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jkan2001 &raquo;</TD></TR><TR><TD CLASS="quote">How did you run 16 pounds on a stock internal D16Z6? Is that just with a blockguard and a thicker headgasket or something? I'd be more than happy to make 220 whp with the SC50, which manifold did you guys run on the SOHC with your SC50's and where can i get the manifold/downpipe?
If i'm not mistaken the SC50 is the smallest precision turbo, would the SC34 be too big for street driving on low boost?</TD></TR></TABLE>
I have the SC34, i think you'll have killer top end. you'll be a little laggy but nothing to big to worry about. Just learn where your strong points are.
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX &raquo;</TD></TR><TR><TD CLASS="quote">Thanks bro!
Brian</TD></TR></TABLE>
I am also using the same turbo as Brian. Can't wait to get my motor in!!!
Old Oct 6, 2003 | 02:18 PM
Jkan2001's Avatar
Default Re: What do you guys think of the SC50 on a d16? (HybridcivicLS-T)
Hey, is your civic a 6th gen EX coupe? I think i talked to you at sonic, i have the white 00 ex coupe with the APEXi kit. I think you raced that riced out type R and spanked the sh*t out of it.
Old Oct 6, 2003 | 02:21 PM
BoostedED9's Avatar
all i changed on teh motor was the headgasket (2mm greddy) and arp head studs, hte motor was very very old also 160k+ of pretty hard driving. i used the drag mani and didnt have to cut anything other than the stock fan shroud.
Old Oct 6, 2003 | 05:00 PM
Jkan2001's Avatar
Did it ever blow up on that much boost? What fuel setup do you have and what did you tune it with? I'd be very happy to run a bar with a thicker headgasket/blockguard/head studs, you think that's possible?
Old Oct 6, 2003 | 05:36 PM
jazz215's Avatar
how many lbs were you running to get those #'s?
Old Oct 6, 2003 | 05:56 PM
Boltz's Avatar
ive got an sc32 .60 .63... havent gotten a chance to take it past 5k rpm but it builts boost just fine and im sure the top end will be killer
Old Oct 6, 2003 | 06:14 PM
Jkan2001's Avatar
Default Re: (BoostRotter)
Are you on stock internals? How is the spool up under 5K?
Old Oct 6, 2003 | 06:15 PM
Jkan2001's Avatar
Default Re: What do you guys think of the SC50 on a d16? (jazz215)
I dynoed those #'s on 8 psi with a clogged up stock cat (I had nitrous and ran really rich shooting fireballs which melted my cat) Put a test pipe on now and topend feels 25% better.
Just sold my APEXi kit time to go SC50....anyone think i should go SC32 instead?
Old Oct 6, 2003 | 08:30 PM
DIRep972's Avatar
Smarter than you
what manifolds are all u sohc guys running on w/ ur T3/T4 turbos?
Old Oct 6, 2003 | 09:28 PM
BoostedED9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jkan2001 &raquo;</TD></TR><TR><TD CLASS="quote">Did it ever blow up on that much boost? What fuel setup do you have and what did you tune it with? I'd be very happy to run a bar with a thicker headgasket/blockguard/head studs, you think that's possible?</TD></TR></TABLE>
motor gave way because of a warped head wich dropped water into cyl3 at top end at the track....
DIRep972- i use drag mani but since there are so many out now that its more of a whats cheapest type thing
Old Oct 6, 2003 | 09:37 PM
Jkan2001's Avatar
Can you reccomend a decent/cheap manifold for my setup and where to get it? I'm kind of new to the T3 bigger turbos and i'd appreciate some good advice from you knowledgable D series guys
Old Oct 6, 2003 | 09:55 PM
Arturbo's Avatar
Better than steak
25 Year Member
SC50 with a rev-hard manifold.
Old Oct 7, 2003 | 04:33 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jkan2001 &raquo;</TD></TR><TR><TD CLASS="quote">Can you reccomend a decent/cheap manifold for my setup and where to get it? I'm kind of new to the T3 bigger turbos and i'd appreciate some good advice from you knowledgable D series guys</TD></TR></TABLE>
I have a Maxrev manifold. You can see the car here. https://honda-tech.com/zerothread?id=520599 for more info.
Old Oct 7, 2003 | 06:49 AM
TurbodCX's Avatar
Default Re: What do you guys think of the SC50 on a d16? (ladysman)
I use a DRAG genIII manifold.
I see full boost by 4-5K then it just Fawking pulls like crazy!
Brian
Old Oct 7, 2003 | 02:09 PM
Jkan2001's Avatar
I ended up ordering the SC50 with the .48/.60 from art today along with a tubular 1010 heat treated steel manifold from south florida performance for 450, it looks really nice and i've heard nothing but good things about them. They have 3 yr warranty and the flange for the wg is in the center instead of just on 1 runner. Also picked up their mild steel 2.5" downpipe for 170, i think it was 637 shipped for both items.
I'm excited, should be a fun setup one day i hope to be able to sport the "sohc-T owns DOHC" line in my sig like turbodcx
thanks for all the advice guys.
Old Oct 7, 2003 | 02:28 PM
*Boostwerks*'s Avatar
I am using a SC50 with the .63 turbine on my ZC.
It pulled ******* hard!......Until my oil pressure suddenly went to ****, and i threw a rod.
Did I mention I hate cars?
Old Oct 7, 2003 | 02:41 PM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jkan2001 &raquo;</TD></TR><TR><TD CLASS="quote">I ended up ordering the SC50 with the .48/.60 from art today along with a tubular 1010 heat treated steel manifold from south florida performance for 450, it looks really nice and i've heard nothing but good things about them. They have 3 yr warranty and the flange for the wg is in the center instead of just on 1 runner. Also picked up their mild steel 2.5" downpipe for 170, i think it was 637 shipped for both items.
thanks for all the advice guys. </TD></TR></TABLE>
you made good choices thats gonna be a solid set up.
Old Oct 7, 2003 | 06:44 PM
Jkan2001's Avatar
Default Re: (Bryson)
What were your spool times like on the .63? I opted to go .48/60 on my SC50 also how much boost were you running and why did you lose oil pressure?
