curiosity
i am beginning to save for my engine swap... it will be quite a while with my job but i should be able to afford it in spring next year depending on what i want. I want to have a good turbo platform and (correct me if i'm wrong) aren't sohc the better platforms? i've got a 95 civic dx coupe. i would like some input on what would be a good engine with a decent swap price, and very turbo compatible. i am looking for something under or around 1,500 but if forced to will go up to 2,000. i am hoping this might include a new and better tranny but if i have to save seperate then so be it. input on a good tranny for wanted setup would also be appreciated. thanx
Here check out these sites.
http://www.turbod16.com/
http://www.homemadeturbo.com
And here is some stuff I found using the search. Just type in "junkyard turbo" or "d16 turbo"
https://honda-tech.com/zerothread?id=633512
https://honda-tech.com/zerothread?id=520599
-Hope this helps. You can probably get a d16y8, the junkyard turbo, and still have money for tuning with a 2000$ budget.
