B-series rods on D-series crank?
Old Oct 4, 2003 | 04:55 AM
MrDX's Avatar
Default B-series rods on D-series crank?
I just noticed that the D15B7 con. rod is 134mm in length compared to the D16 motors which are 137mm. By using D16 rods and pistons would increase the displacement.. correct me if I'm wrong. But also noticed that the USDM B16A2 uses a 134mm con. rod unlike the B18B's 137mm or B18C's 137.9mm. Will the B16 rod bolt up to the D-series crank?
Old Oct 4, 2003 | 06:45 AM
NonovUrbizniz's Avatar
Loved
Default Re: B-series rods on D-series crank? (MrDX)
the bottom end fits fine... some people us ls rods others use b16 rods...
There was a guy on here selling kits of machined b16 rods (at the small end) to fit some toyota forged pistons... This was for d16 obviously.
search...
https://honda-tech.com/zerothread?id=589755
https://honda-tech.com/zerothread?id=585598
https://honda-tech.com/zerothread?id=575630
https://honda-tech.com/zerothread?id=552199
those are all resulst for "ls rods"... if you searched for "b16 rods" I think you'd get similar results...
The guy selling the kit was... turbopanda or something like that... hold on... I can't find the thread (I think he doesn't sell them anymore) but I'm pretty sure that's his username...
Good luck...
You re-discovered the wheel
Old Oct 4, 2003 | 07:47 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrDX &raquo;</TD></TR><TR><TD CLASS="quote">By using D16 rods and pistons would increase the displacement.. correct me if I'm wrong. </TD></TR></TABLE> as long as you use the D16 crank as well.
Old Oct 4, 2003 | 09:30 AM
AlphaQup's Avatar
Default Re: B-series rods on D-series crank? (owen_the_soyboy)
read this post bro.
http://pub161.ezboard.com/fbse...topic
also I just had a post running about a simular topic:
https://honda-tech.com/zerothread?id=635520
I'm going to stay with the stock z6 pistons that i have and sell the LS rods that i was planning on putting in.
Old Oct 4, 2003 | 11:02 AM
MrDX's Avatar
Default Re: B-series rods on D-series crank? (AlphaQup)
I ran across the first link bout an hour ago... makes sense. time to re-think some things over.. thanx for the help.
Old Oct 4, 2003 | 03:38 PM
Mista Bone's Avatar
D Tranny Guru
changing the rods and pistons will have NO effect on the displacement.
Only chaning the stroke (crankshaft) or the bore can change displacement.
Old Oct 4, 2003 | 04:07 PM
MrDX's Avatar
Default Re: B-series rods on D-series crank? (Mista Bone)
D15B7
Crower Rods - B93741B sugg. price for the set $677
JE Pistons - 149187 10.5:1 comp
149184 9.0:1 comp
JE Piston Rings - JXC0F4-2953-2
The pistons and rings are for standard bore sizes, refer to http://www.JEPistons.com for .10 and .20 over sizes for both.
Modified by MrDX at 8:34 PM 10/4/2003
Old Oct 4, 2003 | 05:14 PM
Loved
Default Re: B-series rods on D-series crank? (NonovUrbizniz)
I want to personally chastise myself for giving out bad info...
SORRY
sxysweed
May 29, 2012 06:43 PM
mtownsi
Mar 30, 2007 03:17 AM
shiftgear8000
Aug 23, 2004 06:24 AM
98civicEX
Jul 31, 2002 06:28 PM
