turbo, or swap??
well, i have just about everything to turbo my d series engine, since it needs new rings (burning oil) i figure i could spend about 200 on new bearings, and new rings and throw on a turbo... or i could wait, save up and attempt to throw in one of the f- series motors i have laying around,.. yes not a practical swap but i have the engine and know alot about them.. and just about anything i would need to do the swap other then mounts.. the torque from a 2.2L in a CRX would be nice but i still would lack top end.. or go turbo on a d - series like 7-8 PSI at the track 5-6 daily.. and have the top end?.. which would be faster? i think both would have the same HP, about 150 or so to the flywheel.. opinions please, just don't say through in a b16 or something.. i don't have that engine and don't want to buy one, i'm doing one of the 2 i listed because i have most of the parts laying around already.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">well the the fastest front wheel drive has a built F22!! So it just depends on you!!</TD></TR></TABLE>
the fastest ALL MOTOR front wheel drive.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
GSR swap = about 145whp stock - $3-4000
LS swap = about 125whp stock - $1500-2000
B16 swap = about 135whp stock - $2000-2500
SOHC w/greddy kit, stock everything w/blue box@ 7 psi = about 165-170whp - $1000 total! (in my case)
Boost the SOHC
BTW, it's just as reliable as when it was stock.
Do it once.
Do it right.
Do regular maintenance.
Leave it the **** alone.
Boost the SOHC
Do it once.
Do it right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
Do it once.
Do it right.
Amen to that
I say boost the D. Nothing like the sound of a BOV going off to get the attention of everyone around you
Do it once.
Do it right.
</TD></TR></TABLE>Amen to that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anotherEG6 »</TD></TR><TR><TD CLASS="quote">boost the D. you can replace them for so cheap that it doesnt even matter if you blow it up.</TD></TR></TABLE>
true, but if it's your dd i say swap. you keep stock
reliability, and get the power jump. if you are seriously considering a h22 as an option, I'm pretty sure a boosted d series can crest 200hp, but it probably wont retain the reliability, especially if you trounce your motor.
just my two cents
reliability, and get the power jump. if you are seriously considering a h22 as an option, I'm pretty sure a boosted d series can crest 200hp, but it probably wont retain the reliability, especially if you trounce your motor.just my two cents
