Problem with a buddies ep3 need help
Old Oct 3, 2003 | 09:05 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Problem with a buddies ep3 need help
he says he cant get into 4th gear and it grinds when you try to put it in 4th...all of the other gears work fine with no grinding...but now he just cant get into 4th...my friend and i both think its his synchro...any suggestions
Old Oct 4, 2003 | 05:38 AM
jus f0 dekarayshunZ
Default Re: Problem with a buddies ep3 need help (ciRcuitSi y0!)
20 views but no replies im so sad i have tears in my eyes....uh... back up
Old Oct 4, 2003 | 05:50 AM
mhx's Avatar
mhx
your friend cant drive he fked his tranny up..
take it to honda and hope its under warrenty
Old Oct 4, 2003 | 06:12 AM
jus f0 dekarayshunZ
Default Re: Problem with a buddies ep3 need help (mhx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhx &raquo;</TD></TR><TR><TD CLASS="quote">your friend cant drive he fked his tranny up..
take it to honda and hope its under warrenty</TD></TR></TABLE>gee thanks for the help...since my synchros went bad i guess i cant drive either right??
Old Oct 4, 2003 | 06:13 AM
combustion's Avatar
Actually Honda has had a few cases where the transmission was messed up from the beggining. Tell him to bring the car to the dealer and more than likly he will get a overhual of the tranny done.
Old Oct 4, 2003 | 06:16 AM
jus f0 dekarayshunZ
Default Re: Problem with a buddies ep3 need help (combustion)
i already know its under warranty i just want to know what the problem is or what it could be...you know for future reference and what not
Old Oct 6, 2003 | 10:19 PM
jus f0 dekarayshunZ
someone have ANY input at all
Old Oct 6, 2003 | 10:58 PM
CN03Si's Avatar
It sounds like the synchros are bad. This is similar to what my friend is going through except he has an '01 Civic LX coupe. He can't go into 1st gear or reverse and his mechanic told him that it's due to having bad synchros in those gears.
I don't know much about the EP3 tranny and it's reliability. I have an '03 EP3 and it doesn't always shift correctly like it should. Occasionaly, it grinds into 3rd and sometimes its a pain to get into reverse. It's not consistent though so I think the synchros are fine.
I recommend that your buddy takes his EP3 to the dealer and has the tranny looked at. This shouldn't be happening on such a new car and hopefully Honda will pick up the tab to fix it. Good luck.
Old Oct 8, 2003 | 05:17 AM
00MRSi's Avatar
Default Re: Problem with a buddies ep3 need help (CN03Si)
As you mentioned, sounds like a synchro issue. Bring it to Honda. Try replacing the tranny fluid. I've heard great things about GM Synchromesh friction modified tranny fluid. I think it's wortha shot..
Old Oct 8, 2003 | 06:07 AM
combustion's Avatar
Default Re: Problem with a buddies ep3 need help (00MRSi)
do we have to keep the tranny fluid in for a certain length of time like the oil becuase i would like to drop in some redline mtl
stichedskater
Honda Civic (2001 - 2005)
Sep 9, 2007 05:53 PM
SOHC-VTEC-BB2
Mar 2, 2007 01:31 PM
aandDavidsaid
Dec 19, 2004 08:18 PM
Propulsion
Jul 16, 2003 12:47 PM
yellowbuffalo
Jun 25, 2002 09:14 AM
