AEM EMS 30-1010 Maps
I know this may not be the greatest thing to do but I need a fuel map and everything that goes with the map. I have a 2000 Civic Si with a b16a2, 75lb/hr injectors, edelbrock manifold, and Holley 68mm throttle body. The car will start up and run but it will not idle. Way too much fuel obviously is getting dumped in AND when you are at part throttle it sputters and falls on its face seemingly. I just was wondering if anyone had a similar set-up and would be willing to share their maps. I need to drive the car and get a true feel for it before it gets on the dyno at AMS in Chicago. Please respond with an email, pm, and or respone. Any and all help is welcome. Thanks guys!
just call aem...make sure you have your car hooked up to a computer before you call and are ready to make changes...that is if you can get ahold of them...they will run you through step by step on how to setup the program with your bigger injectors so it will idle and run good enough to go get tuned. you have to go in and change the injector size, fuel tables and something else too i cant remember
