just did a compression test
Old Sep 30, 2003 | 06:53 PM
jeremy.'s Avatar
Default just did a compression test
warmed the car up and shut if off...waited 10 min then took plugs out. gassed it and cranked it 4 or 5 times. setup is a b16 head on gsr block with jdm itr pistons. got 240, 210, 240, 235. i dunno what's up with #3. what could be the problem? worn piston ring?
Old Sep 30, 2003 | 07:17 PM
Weapon's Avatar
Default Re: just did a compression test (ek_jeremy)
sorry for being such a n00b
but from this, how do u find ur compression ratio? eg 11.1:1 etc... :S
Old Sep 30, 2003 | 07:22 PM
TimoneX's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">warmed the car up and shut if off...waited 10 min then took plugs out. gassed it and cranked it 4 or 5 times. setup is a b16 head on gsr block with jdm itr pistons. got 240, 210, 240, 235. i dunno what's up with #3. what could be the problem? worn piston ring?</TD></TR></TABLE>
Could be. That's not super bad anyway, but a bit more variance than you'd like to see. Dump a teaspoon of oil in #3 and try that one again. If it goes up near the others it's likely the rings. Otherwise it's probably the valve seals.
Old Sep 30, 2003 | 07:26 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: just did a compression test (Weapon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weapon &raquo;</TD></TR><TR><TD CLASS="quote">sorry for being such a n00b
but from this, how do u find ur compression ratio? eg 11.1:1 etc... :S</TD></TR></TABLE>
You don't.
Old Sep 30, 2003 | 07:35 PM
TimoneX's Avatar
New User
Default Re: just did a compression test (Mr Milano)
Those gauges are too innacurate and there are too many factors to reliably calculate static c/r from it. Even altitude would play a role.
Old Oct 1, 2003 | 03:32 AM
Weapon's Avatar
then how do u find ur compression ratio? :S
Old Oct 1, 2003 | 08:43 AM
TimoneX's Avatar
New User
You calculate it, by hand or with a program.
http://www.c-speedracing.com/h...c.php
Old Oct 1, 2003 | 09:33 AM
BERT-O's Avatar
Default Re: just did a compression test (TimoneX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimoneX &raquo;</TD></TR><TR><TD CLASS="quote">You calculate it, by hand or with a program.
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
isn't there like another site that used pictures of the head, block ,etc................just wondering, I like to plug and play, rather than sit here with nubmers, lol
Old Oct 1, 2003 | 09:48 AM
TimoneX's Avatar
New User
Default Re: just did a compression test (BERT-O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
isn't there like another site that used pictures of the head, block ,etc................just wondering, I like to plug and play, rather than sit here with nubmers, lol</TD></TR></TABLE>
LOL
Sure...for all you romper room fans there's this one too.
http://www.bojangs.com/calculator/
Old Oct 2, 2003 | 01:06 AM
d0nkeyxPunch's Avatar
Banned
hm....i'm guessing piston rings, but I could definately be wrong also.
Old Oct 2, 2003 | 03:56 AM
BERT-O's Avatar
LOL
http://www.bojangs.com/calculator/</TD></TR></TABLE>
yea, yea, yea.........thats the one I was talking about. I like picture and stuff .............brings back memory as a kid
Old Oct 2, 2003 | 04:45 AM
snowseeker's Avatar
Maybe not worn rings so much but a broken or cracked ring will lose around 30 - 50 psi in a cyl.
projectTeG
23
Mar 31, 2010 08:18 PM
EJ1_203
10
Sep 28, 2007 04:28 PM
powerfulperformance
Feb 28, 2005 10:08 PM
lke2drvgsr
17
Jan 17, 2004 12:44 PM
jeremy.
Sep 30, 2003 10:00 PM
