I'll be frickin suprised if anyone can help me with this...
Old Sep 26, 2003 | 08:27 PM
DingleberryDowns's Avatar
Default FRICK CHECK ENGINE LIGHT WHY
ok i got a check engine light on today and no money to take it in, heres the story..
week ago- zex wet kit installed (prelude S f22) - clean *** install, was really easy.
got cooler NGK plugs
2 days ago - filled bottle
checked for leaks in lines
yesterday, did quik run with 55 shot jets- went fine, NO CHECK ENGINE LIGHT FOR REST OF THE DAY/WASENT ONE BEFORE . not a huge noticeable difference in power. havent shot nitrous again yet
noticed clear liquid by nozzle. found a new fitting and rigged it in there last night.
heres what i did between when no check engine light and today: took intake off, unpluged harness ontop of intake manifold right above where intake goes on, drilled larger hole in intake, threaded new fitting in, screwed nozzle in, fits great. put intake back on
get in car today and check engine light stays on after starting car. WHY?
i checked all the haresses i may have bumped around the intake and checked wires to nitrous managment unit.
I DO remeber accidently remote starting my car with the harness unpluged on the top of the intake manifold. this might have done it?
can anyone help diagnose this? how can i check the code? the site i found for codes by searching the boards was for 5th gen only
Modified by DingleberryDowns at 5:38 AM 9/27/2003
Modified by DingleberryDowns at 5:41 AM 9/27/2003
Old Sep 26, 2003 | 08:46 PM
satan_srv's Avatar
Default Re: FRICK CHECK ENGINE LIGHT WHY (DingleberryDowns)
they are the same codes. your blue plug to use is on the driver's side instead around the corner of the center console at the back behind your radio...head in the direction of the as pedal then look behind the plastic console. The blueplug is there, stick in a paperclip turn the key till the panel lights come on and count the blinks. Long is the first number, short is the second.
Old Sep 26, 2003 | 09:17 PM
BoostedH23a1's Avatar
Default Re: FRICK CHECK ENGINE LIGHT WHY (satan_srv)
to the right of the gas petal beind the radio..i think its tan and white one wire and other is blue maybe.. not sure..
Old Sep 27, 2003 | 12:20 AM
Default Re: FRICK CHECK ENGINE LIGHT WHY (BoostedH23a1)
thanks, figured it out about 4 minutes after i posted, starting my car with the throttle body harness thing unpluged must have been it like i thought. disconnected neg batt. terminal to reset my ecu and light was off.
Old Sep 27, 2003 | 12:26 AM
flip1199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DingleberryDowns &raquo;</TD></TR><TR><TD CLASS="quote">thanks, figured it out about 4 minutes after i posted, starting my car with the throttle body harness thing unpluged must have been it like i thought. disconnected neg batt. terminal to reset my ecu and light was off. </TD></TR></TABLE>
That's not how u reset the ecu. To reset the ecu, unplug the clock radie fuse for 10secs then put it back in.
Old Sep 27, 2003 | 12:46 AM
Default Re: FRICK CHECK ENGINE LIGHT WHY (flip1199)
really? i read on another post u can do it either way... anyways it worked
Old Sep 27, 2003 | 12:53 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">
That's not how u reset the ecu. To reset the ecu, unplug the clock radie fuse for 10secs then put it back in.</TD></TR></TABLE>
well disconnecting your battery is like pulling ALL of your fuses...so he did accomplish the same thing.
Old Sep 27, 2003 | 12:56 AM
i figured either way was gona reset all my ****** eq settings and my hood was already open..
wrice4
Honda S2000
35
May 12, 2007 09:39 AM
thielke2004
Oct 1, 2005 12:17 PM
StraightCivic
Jul 1, 2005 01:53 AM
SIIK
Honda S2000
Sep 2, 2004 07:28 PM
95sihb
Oct 10, 2002 11:34 AM
