just a simple wiring question.......
i just bought a panasonic CQ-DFX883U, and i was just wondering for a 96 civic dx, is the battery lead yellow, or is it red?
and is the power lead yellow or red?
im normally good at installing these, but im used to it being called the ACC wire, and i just got confused
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">ACC == Accesory, and will be the red wire.
The Yellow (BATT) wire is the constant 12v.</TD></TR></TABLE>
so.........if i hook the acc wire up to the battery wire, and the constant wire up to the acc wire, will it turn on if the car is on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy »</TD></TR><TR><TD CLASS="quote">
so.........if i hook the acc wire up to the battery wire, and the constant wire up to the acc wire, will it turn on if the car is on?</TD></TR></TABLE>
ACC = like when you have your key in the ACC position of your ignition your radio will have power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">The Yellow (BATT) wire is the constant 12v.</TD></TR></TABLE>
constant 12v will give the radio power all the time even when the car is off (no key)
to answer your question... yes it should... but why would you do that?
just do what the instruction tells you if i were you... coz if you fry anything, dont blame anybody. or you want power to your radio all the time?
that's backwards.
The red ACC connects to the wire that only shows 12 volts when the key is turned on.
The yellow batt wire connects to the wire that is always 12 volts
that's backwards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MileHigh »</TD></TR><TR><TD CLASS="quote">
im not doing it purposely, i just got the names mixed up.
thanks for all the help
red1997civic
Dec 25, 2003 12:50 PM
BodyKits NW
Aug 9, 2003 12:38 PM
