I need some wiring help.
Old Sep 26, 2003 | 07:00 PM
Drew96EJ's Avatar
Default I need some wiring help.
Hello,
I have a d16y7 in my civic. I am using an EX manifold and EX wiring harness. I am putting a DX throttle body on the EX manifold because I have to use the DX IACV w/ the DX ECU, since the DX ECU needs the 3-wire IACV (the 2-wire EX IACV which is on the manifold itself will obviously not work with the DX ecu).
Anyway, I am obviously going to have to add the 3rd wire to the EX harness for the IACV. What are the correct pinout locations for all 3 wires for the IACV? I'm pretty sure it's A12 through A14 or something, but I don't know which wire goes in which location???
This is really confusing for me, and any help would be MUCH appreciated.
-Andrew
Old Sep 26, 2003 | 08:03 PM
Drew96EJ's Avatar
Default Re: I need some wiring help. (tuner419)
Also, the wiring i have is not color-coded the way it should be (using a different plug that i found at a junkyard that happened to fit onto the IACV itself), and of course the 2 wires from the EX IACV + one wire that I will be adding....
This means that I do not know which prong coming out of the IACV is for +, -, and the control wire.
This must sound crazy.........but I need to get it done somehow....
Old Sep 26, 2003 | 08:10 PM
Drew96EJ's Avatar
i do have this information: http://www.ff-squad.com/tech/w...2.jpg
maybe that will offer some insight that someone can translate into what i need to do???
thanks again
Old Sep 26, 2003 | 10:33 PM
BatuKing's Avatar
I know that the
Ok going by looking at the pictures here is what I think..
With Clip for IACVon the top and going from right to left
1st pin will be A12
2nd Pin will be A14
3rd pin will be A13
So If I am correct you just want to convert a 2 pin wire to a 3 pin wire..right?
Old Sep 27, 2003 | 08:44 AM
Drew96EJ's Avatar
Default Re: I need some wiring help. (BatuKing)
yes, if what you're saying is correct, i just have to add a wire
Old Sep 27, 2003 | 09:58 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner419 &raquo;</TD></TR><TR><TD CLASS="quote">yes, if what you're saying is correct, i just have to add a wire</TD></TR></TABLE>
Yes but I am not an expert on the IACV but just by looking at the wiring thats what is required
MansuDC2
Aug 3, 2005 07:28 PM
KiNG $h!t
Jan 30, 2005 09:37 PM
pheen0m
Jan 17, 2005 12:57 AM
DteKMotorwerkz
Jan 30, 2004 07:05 PM
Drew96EJ
Sep 23, 2003 01:49 PM
