Flapping noise under acceleration....timing belt?
Old Sep 26, 2003 | 01:37 PM
4bidden's Avatar
Default Flapping noise under acceleration....timing belt?
Lately when I am accelerating from a stop light or something, I hear a very distinct flapping noise coming from the engine. I popped the hood and at idle the timing belt area seemed very loud. Can a loose timing belt make this much noise? I just fixed some exhaust leaks, so I know what those sound like, and this isnt the same. However, this does seem to get louder with throttle position.
Any ideas? I have the valve cover off right now doing a valve adjustment, let me know if there is anything I can look for while I have it off besides timing belt condition. It was changed <20k miles ago btw.
Old Sep 26, 2003 | 02:21 PM
4bidden's Avatar
Default Re: Flapping noise under acceleration....timing belt? (4bidden)
Here are two pics of the timing belt.
Read some old posts and some said its the auto tensioner about to take a crap....could this be true?
Old Sep 26, 2003 | 02:33 PM
4bidden's Avatar
Here is a video of me showing the play in the belt between the cam gears....I have no idea if this is significant or not.
(2.56MB) http://www.forbiddenmotorsports.com/tb_vid.avi
Old Sep 26, 2003 | 03:10 PM
4bidden's Avatar
Default Re: (4bidden)
Here is a vid of the play on the exhaust cam side of the timing belt
http://www.forbiddenmotorsport...1.avi
Old Nov 8, 2003 | 02:06 PM
biglew's Avatar
I got the same problem I think. I hear a flapping type sound around my belts, sounds like it's coming from behind my timing belt cover area, ever fix this? If so what was it?
Old Nov 17, 2003 | 06:39 PM
99spanishGT
Guest
Posts: n/a
Default Re: (biglew)
hey man its me again im having the same problem i can feel it in my clutch pedal so i dont know if its something with my clutch. i also have a sqeaky belt that started up 3 days ago and i havent looked to see which one. maby you could look at it on friday. did you already regester. they are allowing walk ups id be there by 7:30 . ill ask tommorow and tell you back on this post. later
Old Nov 17, 2003 | 07:01 PM
4bidden's Avatar
Default Re: (spanishlude)
I'll check it out on Friday, no problem.
I also got a squeaky belt, most likely from all the fluids I have spilled on it recently. A tightening helped a bit, but didnt take it away.
I'll be there at 8 or so....hopefully with my new CF fog trim covers, right JOEL!!!
Old Nov 17, 2003 | 09:29 PM
JG Luder's Avatar
I've heard that sound about... oh.... 4 times. All four times I jumped the timing belt within two weeks.
If it was my car my first reaction would be yank the auto tensioner and replace it. Bent valves and holes in pistons suck.
Old Nov 17, 2003 | 09:31 PM
4bidden's Avatar
Default Re: (Lone Luder)
This thread is way old. I already swapped to manual tensioner.
Old Nov 17, 2003 | 09:36 PM
JG Luder's Avatar
wow... resurrected from the dead and I didn't notice.
I'll just go and play with leaded paint chips now...............................
Old Nov 17, 2003 | 10:49 PM
biglew's Avatar
Yeah that was my fault, I didn't want to get mobbed by the SEARCH *****.
Old Nov 18, 2003 | 10:24 AM
david90's Avatar
ur tb is too loose!
Old Nov 18, 2003 | 04:09 PM
JG Luder's Avatar
Default Re: (david90)
wait wait wait.... you have a muffler bearing going bad. I've seen it a dozen times. I work at a shop... I know this stuff..................
Old Nov 18, 2003 | 04:16 PM
4bidden's Avatar
No no, I already checked it and filled it with coolant.
Old Nov 18, 2003 | 04:23 PM
JG Luder's Avatar
oh, see? That's where you went wrong. Use half MTF and half brake fluid... (dot 3)
Old Nov 18, 2003 | 04:24 PM
4bidden's Avatar
Crap. I was just at AutoZone and got some Mugen bearing fluid off the shelf...that should work, its Mugen.
Old Nov 18, 2003 | 04:36 PM
JG Luder's Avatar
yeah, anything that's $127.78 per 12 oz. bottle will work.
barryfaetheus
Jul 23, 2011 09:47 PM
ceehris
Dec 13, 2006 10:10 AM
bam181
Aug 20, 2006 05:16 AM
petrv
Mar 1, 2004 10:32 AM
petrv
Mar 1, 2004 09:56 AM
