Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone have oil starvation problems w/ stock oil pan?
Old Sep 23, 2003 | 12:14 PM
nmhybridog's Avatar
Default Anyone have oil starvation problems w/ stock oil pan?
Running b16a in an 89 civic. Car is going to be for road racing. I was wondering if any of you guys have oil starvation problems.... Is a mugen oil pan worth the 250 or is there some trick you guys use to keep the cost down. I know the Morosso is like 400 bucks or something like that. Do I even need either of these?
Old Sep 23, 2003 | 12:24 PM
B18CXr's Avatar
Default Re: Anyone have oil starvation problems w/ stock oil pan? (nmhybridog)
nope
Old Sep 23, 2003 | 12:33 PM
Todd Reid's Avatar
Default Re: Anyone have oil starvation problems w/ stock oil pan? (B18CXr)
i'll second that "nope". i run an LS race motor in my H1. never any oil starvation; never seen the gauge dip below 65 psi whenever the motor is over 3500 rpm.
i keep the engine oil topped up to slightly overfull.
Old Sep 23, 2003 | 02:18 PM
Track rat's Avatar
Default Re: Anyone have oil starvation problems w/ stock oil pan? (Todd Reid)
Tracking an ITR on track tires and never a problem with pick up or pressure, I just wish I didn't burn nearly quart every hour!
Old Sep 23, 2003 | 02:19 PM
bb6h22a's Avatar
I run 0.5 +/- quarts over at the track, and have never seen the oil light come on.
Old Sep 23, 2003 | 02:34 PM
Chris N's Avatar
Default Re: Anyone have oil starvation problems w/ stock oil pan? (bb6h22a)
I have had vtec cut in/out with the stock pan, but that is because i'm burning oil, and when the level is down a bit.....
I was thinking of doing a D and having my stock pan baffled, cept I can't weld. So i'll have to look into some welding services locally.
Old Sep 23, 2003 | 04:12 PM
krshultz's Avatar
In, well...a LOT of track miles in my GS-R, I've never dropped out of VTEC due to oil starvation. Stock pan. I too keep it slightly overfull.
Old Sep 23, 2003 | 08:56 PM
kb58's Avatar
Banned
Default Re: Anyone have oil starvation problems w/ stock oil pan? (krshultz)
Okay, I have yet to hear the experts regarding this:
Mid-engine Mini (old style)
200hp (or thereabouts) H22A1
1600lbs race weight with driver
40/60 rearward weight distribution
Sticky street tires
Will the stock pan suck air on a road race track?
Old Sep 24, 2003 | 03:44 AM
Todd Reid's Avatar
Default Re: Anyone have oil starvation problems w/ stock oil pan? (kb58)
hi. that is going to be a mean mean track machine!!
Corey would know better than I, as he races a Prelude VTEC, but i believe that the H series motors are much more likely to starve for oil than the B series. i have seen corey drop out of VTEC at the track; i would assume that this was caused by oil slosh...
good luck with the Mini!!!
Old Sep 24, 2003 | 03:56 AM
.RJ's Avatar
.RJ
even with corey has said his motor is full/over-full he was starving last year in T8/T9 at slummit. I remember this conversation from the paddock:
Corey: Its cuttin' outta vtak
Yack: You gotta Add oil
Corey: Its full
Yack: Add oil
Corey: Its probably 1/2 qt overfull
Yack: Add oil
Corey: You sure?
Yack: Add oil
This might also help: https://honda-tech.com/zerothread?id=493919
Old Sep 24, 2003 | 04:03 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nmhybridog &raquo;</TD></TR><TR><TD CLASS="quote">Is a mugen oil pan worth the 250</TD></TR></TABLE>is the price worth motor insurance? it is a nice investment IMO.
I don't burn that much oil.... but if there was excessive burning and longer sessions the level 'could' drop below a suitable level.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nmhybridog &raquo;</TD></TR><TR><TD CLASS="quote">is there some trick you guys use to keep the cost down.</TD></TR></TABLE>find a used one like I did.
Old Sep 24, 2003 | 07:35 AM
kb58's Avatar
Banned
Default Re: Anyone have oil starvation problems w/ stock oil pan? (Willard)
I know this has been previously beaten to death, but no one has mentioned an Accusump.
Petah
May 2, 2009 02:24 PM
flipstar760
12
Dec 17, 2006 05:07 PM
ekim952522000
Dec 12, 2005 04:47 PM
Muckman
Jul 20, 2004 01:35 PM
SoloSol
Nov 13, 2001 07:41 AM
